this pyramid should produce electricity. (thomas trawoger's pyramid explaned.)
Started by nitinnun, July 16, 2008, 04:57:47 AM
nitinnun
i drew all of the pyramids by hand, without measuring their angles.
because that was the casual thing to do, and the other details were what i wanted to communicate.
the angles of the pyramid aren't very important.
unless you need certain frequencies.
wile_coyote7
 ;D  @ nitinnun
No.....I'm not at all talking about the angles of the pyramids in your drawings. No complaints there at all!
What I mean is, in that last drawing of yours, you are explaining CW and CCW and copper and steel and all of that. It just looks like you threw in the shape of a pyramid amongst all the other stuff, not really explaining what effect the pyramid shape is having on the CW and CCW and all that other stuff.
I guess I'm just asking for a little more clarification on what the pyramid is doing along with all the other stuff you have been explaining.
(Please don't think I'm trying to be critical of your work here)  :-\
?When the power of love overcomes the love of power, the world will know peace.?
Jimi Hendrix
nitinnun
my intent was:
the middle of the pyramid, is the ideal place to collect CW.
because the middle of the pyramid, seems to be where CW builds up the most.
judging from the kings chamber, thomas trawogers claims, and countless other peoples claims.
the copper ring "collects" CW.
CW moves toward the capacitor, trying to get closer to the steel.
the base of the pyramid, is the best place to collect CCW.
because the base is closest to the ground, which is the greatest source of CCW.
the opposite, of how the air is the best source of CW.
the peak is the negative charge, on the pyramid.
but the peak needs as much CCW as possible, with which to attract CW from the sky.
if the peaks CCW were drained, than the pyramid would lose its capacity, to attract and trap CW in the middle!
think of a steel flagpole, standing in a field.
this steel flagpole, generates its own CCW. and conducts CCW, from the ground.
CW from the air, is attracted to the steel flagpole, because of its CCW.
the CW of the air, mixes with the CCW in the flagpole, to create lightning.
wile_coyote7
@ nitinnun
Thanks for clearing that bit up.
So, can I be so bold as to make an analogy to the CW, CCW scenario (as I am understanding it)?
CW and CCW = vortices of energy?
CW = positive (+) (air)
CCW = negative (-) (ground)
Pyramid shape and others like it harness or attract these vortices somehow or, for lack of a better term, 'orders' them? (I am thinking like the shapeless being forced into shape or chaos into order.) (key words: attract, order, organize, concentrate, etc)
Am I even close in my analogy???
Sorry for all of the questions.
Jimi Hendrix
nitinnun
questions, are how i found this information.
i shamelessly asked questions, out loud and on paper.
and maybe some pleiadian or sirian answered me, through my intuition.
they guided me to pieces of information. online and in my day dreams.
but i had to use my judgement, to sepperate valuable information, from waste-of-time information.
and i had to use my subconscious mind, to make a connection, between 2 or more pieces of information.
i did 80% of it.
they guided me to the 20%, that was hardest to find.
electricity, is made of clockwise and counter-clockwise spinning "energy".
i don't know what this energy "is".
but a vortex, is spinning energy.
so i guess that CW and CCW, are oppositely spinning vortexes.
i think that orgone, chi, and the energy that sensitive people feel, are clockwise spinning energy.
sources of water, are oozing with CW energy. which is why people are naturally attracted too them.
to soak yourself in water, is literally to soak yourself in life energy.
to drink water, is to fill your body with nanoscopic life-generators.
CW spin is generated from protons, which always spin CW.
CCW spin is generated from electrons, which always spin CCW.
a diagonal spinning tempic field, seems to be generated from neutrons (a neutron, is a proton stuffed into an electron).
some atoms have more protons than electrons.
or more electrons than protons.
or for whatever reason, an atom just plain spins harder CW, than CCW.
or spins harder CCW, than CW.
every water molecule, spins more CW than CCW.
because the 2 hydrogen atoms generate more CW, than the oxygen generates CCW.
every silicon dioxide molecule, produces more CCW than CW.
because the 2 oxygen atoms generate more CCW, than silicon generates CW.
that is right.
water generates one half of electricity, for free!
sand generates the other half of electricity, for free!
the air moisture in the sky, and the sand in the ground, generate lightning bolts.
for free.
the pyramid shape "collects" CW from the air.
the CCW in the peak, attracts CW into the middle.
then sand/steel in the pyramid, "holds" the clockwise in the middle. like a baseball mitten holds a baseball.
then the CCW in the ground, attracts the CW downward.
but the CW cannot reach the ground and discharge into the ground. because all 4 pyramid edges pull on the CW, giving the CW no way to reach the ground.
the CW wants to travel down to the ground, along every 1 of the 4 edges!
but it is not allowed to pull itself down just one edge. it is attracted down all 4 edges at once!
so the CW stays trapped in the peak, wanting to flow, but not being able to choose an edge to take.
if the CW were in a steel pole, than the CW would have only one way to reach the ground.
the CW would take this one path to the ground, instantly.
if you welded 4 steel poles into a pyramid, than the CW would have 4 ways to reach the ground.
the materials that make up the pyramid, determine how high the CW and CCW may build up.
just as a large bucket can hold more water, than a small bucket.
any build-up of CW and CCW, can be mixed into electricity.
most of the pyramids electricity, comes from collecting the polarized/trapped CW and CCW.
