this pyramid should produce electricity. (thomas trawoger's pyramid explaned.)
Started by nitinnun, July 16, 2008, 04:57:47 AM
professor
You call it whatever  you wish I call it proof of concept.
To blindly believe is not normal human behavior.
Did you believe there where Weapons of mass destruction?  Many of us poor souls perhaps did so . It was necessary to proof to you and the world that you were misinformed .
Misinformation happens every day in our life.
Nice to believe in something but its not a perfect world.
It takes as much  courage to proof a point as it does do disprove it.
Remarks like yours to expect everyone to blindly believe in something like perhaps you do are unproductive and serve no other purpose but to start an argument that can not be won.
I will therefore no longer respond and let the weight of my comments be determined by each individual free thinker out there.
Professor
Quote from: nitinnun on July 31, 2008, 09:07:45 PM
doubt based thinking, steals from you.
it does not reward you in any way. it only takes away what you "could" have.
doubt based thinking, will not benefit a persons research efforts.
anymore than a brick tied around their leg, will help them to swim better.
even if i am not able to get my design to produce anything, than my design and my explanation of its physics, are further to the truth than anything before.
but doubt based thinking, does not allow you to see the improvement.
it only shows you the way to failure. not to success.
nitinnun
i'm not talking about "blindly believing" anything.
i'm volunteering possibility.
possibility being too dry around here for my taste.
it is YOU, you are preaching blind belief.
blind belief, in the religion of DOUBT.
with a second helping of black and white thinking.
the weight to your comments, is how much of an unhelpful drag they are.
a dead horse around my neck. which was never alive to begin with.
a weight that i need not contaminate my intuition with.
by the way. nothing in this universe, can be proven or disproven.
everything is just a possibility.
everything is just an educated guess.
everything is just an over-glorified opinion, dressed in sheep's clothing.
so don't get caught up in proving ANYTHING.
because you might as well be chasing your own tail, while bashing your head against a brick wall.
into infinity and beyond.
Quote from: professor on August 01, 2008, 03:40:22 PM
Professor
nightwynd
Wow...this thing just turned all philosophical and stuff...
I don't know if this thing will work. I hope it does. If it doesn't, then I'll have a cool looking pyramid in my bedroom. If it does, well - we'll see. In the mean time, I'm still trying to find copper foil or flashing that I can actually afford (budget is insane right now). Keep us posted on progress nitinnun, your build looks interesting. How are you planning on making the base? Did you install the antenna yet?
Nightwynd.
Need motivation? Read: http://www.lifeaftertheoilcrash.net/
Sincerely - nightwynd
nitinnun
i want to cut dozzens of slabs of aluminum foil.
then i will stack them up like a deck of cards.
then i want to fold the edges, to bind them into 1 sheet.
then i want to zip tie together 2 sheets. and reinforce the middle, with plastic straws.
then i will bend the edges, drill holes, and zip tie. like with the copper peak.
then i will line the top with non-conductive duct tape. and sit the copper peak on top.
and if for some unthinkable reason i fail to get electricity, i will screw around with the pyramid until it DOES produce electricity.
because i can see many possibilities which might lead to success.
unlike SOME people. who think that the failure-monster is hiding under every bed and in every closet.
nitinnun
i made another shocking yet basic discovery.
look at the letter "A" on your keyboard.
the letter A, looks like a pyramid.
the line through the middle, electrically sepperates the peak from the base!
the person who invented the letter A thousands of years ago, knew that the pyramids peak must be electrically sepperate from the pyramids base!
they knew how to harvest electricity from a pyramid!
