Selfrunning Waterpump-generator device runs 60 Watts lamp...
Started by hartiberlin, July 16, 2008, 03:09:31 PM
hypersoniq
@JDHardy54... why not run that outlet to the outside of the unit? Less shock hazard that way.
chep
Hello everyone. I'm new here, but I read some of you don't even work on the subject before saying its false.
Anyway it is obviously a fake, for the simple reason that the earth is plane and gravity dont exist yet ,)
Only joking
The pump always need the same energy to run so we have to find the more power/watts pump we can have.
a venturi (and even a kind of vortex make just before the pump like you can add to your car, it might help) would be a great add to the water speed
Dont forget gravity who add power to the falling water (this is free energy btw)
What about using a lesser compressible liquid like oil or break liquid (yes its f**ing expensive but once it will be proven that its work i mean)
Next we can replace the weel near the generator by a magnetic (no physic link betwen the big and the small) and get less friction
It might be a good Idea tho replace the generator by few discoide generators? (they might be more efficient because they move easely, and between each you can add a rotating axis with magnetic gates wich in my mind cost less energy to keep running that it give itself when turning at high speed)
Is mixing few of the ideas of this forum a good idea? I whould say yes (especialy about magnetics motor. Each on is trying 1 way but who try to mix few who ad complementary propreties?
Sorry about my english. It will come back as I will write here
therealrasta
This guys inventions is just a much OU as taking a large fan and blowing it down a wind tunnel with a turbine generator.. LOL!
@ Chep
No gravity energy gained here sir.. The pump is pumping the water up a pipe = lost power due to gravity.. The pipe shoots the water down to the turbine = power gained by gravity.. Conclusion = 0 zero power gained.. Now add friction and it is - power gained.. That is not including the loses in pump and the generator as well.
Lakes
If he puts the whole thing on casters and runs it up to speed with an electric drill or something else with a rubber wheel on, remove the starter device (drill etc) and let it run for an hour outside with no external input (longer videos with GoogleVideo I think) then this will be interesting....
innovation_station
keep up the great work guys
you might get my intrest back in my turbine and gen set ....
but im still on the coil thing ......
and solveing tesla pattends ....
but ya never know ....
the main problem with my turbine right now it is broken the plastic it had a spill out the door ....
but i may fix it to test some new genny designs i have come up with .....
ist
as well the people i showed it to b4 just bought a 2500psi  pressure washer ...   ;D
the most i have seen it run so far on was 1500psi... and it sure was impressive  8)
