Linnard?s hydrogen on demand system without electricity !
Started by hartiberlin, October 04, 2005, 06:54:25 PM
dankie
ppl seem to have fallen in love with waterboys theory at oupower.com
the simplest way to ever get a motor running on water would be a modiied sparkplug/injector called an ELECTROSPARY SPARKPLUG
google : electrospray ionization
the sparkplug acts as an injector and sparkplug , the water is held by capilaryty gets reloaded with amazing stability at very high speed ,( this thing will never break unlike a fuel pump.)
http://youtube.com/user/wwwshark
http://youtube.com/user/elysiumcerulean
as per us patent ########### 7198208
who needs gas intake anyways? water holds hydrogen,oxygen and nitrogen, just round-off the air intake camshaft or weld it shut .This setup needs the vacuum created by the motor to facilitate electrolysis, . Timing must be perfect , as the piston goes down , the fuel chamber gets hit with enough voltage to instantly vaporize the gas .When this thing comes out, its ionized and atomized  , the molecules or atoms search  to distance themselves (this is a good thing).Next phase ,the piston compresses the ion gas , then zap it again with much higher voltage then was used to turn the water into gas-vapor . then BOOM . Thermal ignition shockwave or w/e you wanna call it . The few drops of water get refilled instantly by voltage , very simple .Exhaust that the steam out and start again. Im not sure if the motor would run cool enough that this would work. The ignition timing is the same , the only that changes is that a second voltage pulse is needed before the ignition in order to blast out the water in the expanding vacuum.
Maybe install a laser in it or w/e , might not even be needed. Ppl have got to thik how to apply it to an engine, not just making lots of bubbles
So what is needed basically ? a modified sparkplug that works perfect  ( HARD ), a second pulse (EASY) .... i think thats pretty much it
nothere2win
Here's a quick drawing of a few things you could try, the strips on the inside being the easiest. Just some thoughts.
loosecannon
dankie,
those sound like cool ideas, but you really should start a new thread to discuss them.
i dont mean any offense whatsoever, but this thread is petty dedicated to one experiment at this point, and we really should keep the focus of this thread on that experiment.
i will be checking those links though.
LC
ResinRat2
Hi All,
This is just an update on how it?s going. The large glass reactor is a failure. I cannot stop the leaks and I believe either that the reactor sides are bowing too much or that the glass sides are contracting as the temperature drops during the reaction. The sides pull away from the seams and start the leaks. I cannot fix this one and make it work.
I am starting on a new apparatus and hopefully it will solve all these problems, it should be less expensive to build too.
As soon as I have it working I will show a video of it.
I apologize greatly for all the previous updates and hype. I thought for sure it would work, but I was wrong. I won?t bother to post anything until I get something running. That way I won?t waste your time on my failures.
Super God
>9000
