Linnard?s hydrogen on demand system without electricity !
Started by hartiberlin, October 04, 2005, 06:54:25 PM
ResinRat2
Hi Robert, you wrote:
"In the original setup as proposed by Dr. Griffin, either the zinc cathode has to be replaced or it has to be regenerated, right? In the first case, where you would replace the cathode, wouldn't that leave residue (zincates?) in the reaction medium and evt. spoil the medium???"  My hope is that by regenerating one of the zinc anodes at the same time the hydrogen is being produced, the formation of the zincates will be minimal. That way the chances of this happening will be small. The reaction itself regenerates the zinc by using the magnesium colloid:
2Zn+2 + 2Mgc --> 2Mg+2 + 2Zn(this is the zinc that replates)
the rate just does not quite keep up with the zinc ion formation, that is why the extra regeneration with the electrical current is needed.
"If this is the case then we can only go the path of regenerating the zinc cathode.... This then brings me to my second question, does the regenaration of the cathode cost less power then the power you received from the cell?" I will be doing this with two fuel cells (one after the other). One fuel cell will power the fan (or whatever I hook to it) and the second smaller fuel cell will do the regeneration. That is what my long term testing will do. Show how to maintain this system.
"something else.... I was thinking about your idea of regenerating one cathode(you mean 'anode') while the other one is used in producing hydrogen. Will the current that you put in the reaction medium to restore the zinc not interfere with the hydrogen producing proces on the other cathode/anode set? I mean you're putting a reversed potential on the cell, will the result not be zero because there will be hardly any current flow?
I'm not sure of this but maybe it is somehow an idead to do this across two seperate cells. That is..... use the second anode/cathode pair to regenerate a cathode in a separate second cell (not producing hydrogen at that time)." You might suspect this would happen, but my previous lab tests show that this does work. I can produce hydrogen and regenerate the other zinc anode at the same time. At least that is what it showed in my initial testing of this idea. I still need to try it long-term.
Thanks everyone for your interest.
dutchy1966
Hi everyone,
I'm about to build a cell based on Dr. griffin's patent and RR2's experiences. I just have a hard time finding a shop to order magnesium colloid. The silver colloid is no problem.....
Can anyone point me to a webshop where i can order it? Preferably in Europe but if neccesary anywhere is fine.....
Thanks for your help!
Robert
ResinRat2
 www.wateroz.com
This is were I order magnesium and silver colloids through the internet.
Good luck Robert.
I just got back home from vacation yesterday. I can FINALLY get back to work. Washington DC was cool, but I think hydrogen is more interesting. LOL!
Super God
Hey ResinRat!  Glad you had a good time in DC!  Good luck in your experimentation.
>9000
Paul-R
Quote from: dutchy1966 on August 05, 2007, 05:43:04 AM
Hi everyone,
Robert
Stefan produced a method for silver colloid which was the passing of
a modest current through silver electrodes for a certain duration of
time to produce a certain concentration in ppm using distilled water.
Stefan:
Will the same idea work using magnesium electrodes?
What do you suggest for voltage, current and time for a given concentration?
Paul.
