Linnard?s hydrogen on demand system without electricity !
Started by hartiberlin, October 04, 2005, 06:54:25 PM
TheNOP
Did you made sure that the replating is done fully ?
My guess is what you might think is OU is in faq a lost to the replating process.
Soonner or later you might have to "recharge" the cell to replate properly.
Weight the zinc electrode, run the cell for a few days, then re-weight.
hansvonlieven
G'day Dave,
This is just a quick idea regarding your problem.
It would appear to me that if you can equalise the pressure between the two gas chambers your problem would disappear.
Why not separate the two sections with a flexible membrane like in the diagram below?
Hans von Lieven
ResinRat2
Hi Hans,
Thanks for the suggestion but I think I have found a simple solution. I just took the hose on the oxygen side and secured it so it is straight up in the air. If the hydrogen pressure gets a bit high the liquid can just climb the tube until the pressure is equalized. The liquid can also be drawn down if it gets to low. The oxygen can now also escape easily. Looks like it has been working great for the last three hours, the longest I have had it running at a stretch without my intervention. Looks stable, the liquid levels are staying even, I think the problem is solved.
Hi TheNOP,
The zinc is regenerating, I can see it and the oxygen bubbles slowly coming off the electrode. Voltage=0.812 , Amperage=3.93mA. The fan is running at full blast: off the small fuel cell. Voltage=0.744Volts, Amperage=47mA
That's the overunity amount. The fan is running very fast. I think I can put more load on it. I have been experimenting to see whether to use the small or large fuel cell for regeneration. They both give the same readings for draw at regeneration.
I am going to let this run and run, swithcing the zinc electrode connections once a day. This is now a working unit and looks stable.
THIS IS IT BOYS!  This is the working prototype for long term testing. It begins today and continues until something happens that shouldn't happen.
Fingers crossed, but I am only looking for the truth. Is this overunity? Will it run on just water? We shall see.
Posting videos soon.
P.S.  All I need now is a circuit that will charge a 6 or 12 volt battery off the fuel cell. Preferably the large one. Anybody, HELP! lol.
hansvonlieven
G'day again Dave,
Congratulations on your achievement, you have worked long and hard on this and with a great deal of ingenuity. I am happy for you. All the best with your long term tests.
Hans von Lieven
dlwammo
Way to go RR!  Knew you could get there.  Crowd on the sideline is still rootin for ya'....
Good Luck with the testing.
Don't mess with old farts... age and treachery will always overcome youth and skill!
