The Original Pyramids..How they worked a possible explanation
Started by Rocr, July 23, 2008, 06:43:07 PM
Rocr
If you want to understand the real pyramids as they were originally intended to function the story of Dr.
Raymond Browns crystal Which was the real thing and was determined to exhibit some properties of a
synthetic crystalline monopole with what has been called a microscopic metallic latticework embedded in its
structure ...[clearly tech way beyond our capabilities] in the 1970's and would seem to be to this day .
The story of Dr. Raymond Brown is the key to understanding this remarkable ancient technology . While
diving for treasure of the Bahamas near a location called the tongue of the ocean Dr. Brown came upon a
pyramid structure at 22 fathoms the structure was smooth and mirror-like the stone just as the Great
pyramid at Giza was in its prime . The capstone was described to look like lapis lazuli  . Brown found an
entrance and when in although he had no light source the room appeared lit and he saw a brassy metallic rod
approx. 3 inches in diameter hanging down from the apex at its end was attached a faceted red gemstone in
the middle of the room was a stand of carved stone topped by a stone plate with scrolled ends . On the
pillar rested a pair of  metal bronze ? hands which appeared blackened and burnt [clue]  4 feet directly
below the ceiling rod gem point was a crystal sphere 3-1/2 inches in
diameter the crystal appears to have three pyramids in graduating size as part of its structure [this also
with variations is seen in Egyptian representations] .
From the side view appears thousands of tiny fracture [?] lines that Brown felt may be electrical in nature
. A compass needle placed next to the sphere
spins counterclockwise while moving it further away produces the opposite reaction .Metals are temporarily
magnetized in close contact and the crystal Repels metal placed above it ! .
The professionals that briefly studied the artifact were baffled as to its construction but one thing I
heard was that it displayed the properties of a monopole ? .One person that handled the crystal directly
reported that the blood in his fingers rose to the surface of his skin making them bright red .[attracted
the hemoglobin perhaps ?] .
See and Hear Dr. Brown discuss his find and displays its repulsion of metal here ...go watch this
http://www.youtube.com/watch?v=O3ihfpHuBa0
While many have theorized on the crystals properties and function lets take this one step further and see
what we can learn from the Ancient Egyptians themselves .First do we find correlations within the records
of the Egyptians to support Dr. Brown and indeed we do .  . The polished surface that once covered it and
is documented and still seen in the structures that it was stripped to create . The pillar and the hands
are also documented ...But what we need is a schematic of the complete device ...And we have it !
This is not just art it is the basic design of the device stylized yes but as you will see that was the
Ancients way of doing things they used representations especially creatures to give you a perspective of
the item being described . As you can see in this representation the hands are horns . The crystal some
refer to as the solar orb is perched atop it on the pillar and above it the generated field  . Now what is
that at the base of the column a box with two falcons heads ?
I'll tell you .. there is a well known account of a man who was taken into the Royal court by a member of
Pharaohs family adopted as it were who grew up raised in the priestly class to know the secrets of the
Elite of his time and although the technology was in a degenerated state by that time one thing that still
remained and was the source of the power probably still in limited use but as the true function had no
doubt been lost.
That power source we know that was removed was by Moses and was known as the Ark of the Covenant and as the
description of that objects appearance along with the descriptions of it ability to strike people dead at a
distance are part of the record . We can draw a basic conclusion from that when applied to the schematic
above . We also have the "burned" hands described by Brown to me that screams one thing electricity !
This is another representation what does this pillar suggest to you electronics buffs out there taking into
account the the information so far ?
We have a probable high voltage power supply I'm thinking one hell of a battery the ARK [arc ? makes you
wonder about the origins of that word] which was quite easily build-able from common materials of the time
and we have found them going back to Babylon .The stylized workers [gods] who maintained the power supply
obviously had to be protected with some sort of non conductive tools and isolated from ground .
Take this for instance Budge says "Baboon on bank of lake of Fire with flaming braziers "
I say its a depiction of the Energy flow of the Ark They knew Energy and it was depicted as a triangle wave
symbol or a serpent when flowing .
The baboon god was Power get it Power source Here is what they wrote of Babi the baboon god from the Old
kingdom
"He controls the darkness and will open up the sky for the king since his phallus is the bolt on the doors
of heaven. " also known as "eldest son of Osiris" he is also known to 'Kill on sight"..
I think that is something that many who got to close to the Ark without the proper insulation found out the
hard way .
That is fed through some sort of material that in some way modifies the original power into something
usable to charge the crystal to optimum performance .
And if you were creating a device that was on this scale you might dress it up to look like this ?
That in turn is attached to a metallic material on the other end and that cradles a chunk of SIO2 that has
some very strange properties and was engineered to create a specific effect and one that is still beyond
our technology . ?
What was the sarcophagus in the kings chamber really for ? Did it house the power supply ?
Here is something else you may find interesting the tools of the trade so to speak .
Notice that the stylized representation of these "gods" and Pharaohs with their implements .
The rod has dual purpose to it the hook is used to move the crystal balls and their were many in the
ancient days it seems a whole technology was based on them . If you want to move a crystal ball with out
touching it which may be deadly in a functioning device it is the perfect design ..
Then notice the angled end if you need to lift the lid on and off to service perhaps the electrolyte in
power supply in a box [ARK] to service it you'd want a non conductive tool of this sort would you not ?
Slide the angled end into a notch or hole and lift ..
That brings us to the Flail which was a traditional tool for thrashing grain made of wood and wrapped in
metal but in an era that had descended from a high tech on to one of superstition a crystal such as the one
Dr. Brown found would supply you with the opportunity to dazzle the general public with a display of your
godliness by doing the same thing Dr Brown did and make it float above it . And in doing so prove your
right to rule .
So it seems the once perfect device was rendered into a side show for the Pharaoh to take a crystal and
make some metal on a flail float the arms of which moved as if by magic on the EM field . A far cry from
the original intent .. they also used it to enhance things like water and them selves believing that it was
giving them power ..and maybe it did ???
So Lets build it .. now the crystal you know some of its properties we have a power source and current
modification and we have a transmission of the field produced and introduced to a structure by way of the
rod above it to a structure made primarily of SI02 rich stone weighing some approx. 6,300,000 tons
[Pyramid] which may have been cast according to some ..so how about in an electrical field to enhance the
materials ability to convert ambient EM oscillations ?
Once the entire structure starts to resonate sympathetically with the crystal such as the one Br. Brown
found which remember was not electrically charged in his demo .
What do you get ? I believe you have created what amounts to a synthetic third pole on the Earth located at
the very center of the land mass of the continents . This is why all true pyramids found around the world
and on the ocean bottom [and there have been many reported] are found within a certain distance from the
equator . Why ? You Really don't want to destabilize the entire planet while you tap into the plasma sphere
do you ?
Now if this is as our North pole it will provide and EM field path way to draw down to Earth a stream of
plasma like the aurora Borealis .
We also know from the Inuit people who say of those it touches nothing is left not even a tooth in short
they are vaporized .
Now I will not go into the dimensional effects of what being able stand directly underneath this stream of
energy can produce when you are shielded in the chamber below it but modern science has and it is mind
blowing to say the least .. the old hole in time /space thing some very wild theories are floating around
about this and it is also verified by the Egyptian myth and lore .
But you guys are interested in Energy right ? Do you get it now ? Unlimited free energy from the sun spit
out for the taking ..
You could power a World with this and that is no exaggeration think about an average lightning strike ..
not plasma and not spread out over thousands of square miles like the aurora ... One positive lightning
strike could power a large city for days . What could a controlled positive flow of this energy from the
plasma sphere power...Everything !
Why did each Pyramid have a covered entrance that was a long way away from the structure ?
To protect the people coming and going from what could be a very quick death IMO .
Why is there two pits on the South [positive] side of the great pyramid that have at least once been
reported to have traces of having been filled with mercury ? was this part of the process of harnessing the
flow of energy ?
The great white pyramid in China also had mercury pools in it.. [verified]
The big problem with this tech aside from creating such crystals would be triggering an uncontrolled
cascade event which would be catastrophic to say the least .
as an aside ..
The really cool part if the technology is the dimensional field effect on time/space itself it would be
like opening the door to the universe ....
and yes the Egyptians verify this too .. as have experiments that are ongoing today in high energy physics
as to the possibilities along with reports that have observed time dilations at altitude above the poles
The Egyptians believed that to facilitate becoming a star with a light body the Priestly class consumed
what we call white powder gold Research its reported very unusual dimensional and superconductive effects
and some real hard science verifies this .Bristol Myers Squibb research that demonstrates that this
material interacts with DNA by correcting it and it is clear the ancients were producing it and consuming
it .
What is clear to me we are not as advanced as those who lived thousands of years before recorded history
perhaps tens of thousands if you consider how long Dr.Browns pyramid has been on the bottom of the ocean .
Why is another very good question that deserves some serious thought .
Well those are my thoughts and observations . I hope someone will perhaps grasp what I am suggesting and
even take it to the next level in theory of course as a practical model seems nearly impossible unless the
crystal Dr. Brown found can be located and tested further .. or someone replicates them independently ...
PS sorry about the spacing I transferred from a text file .. ???
amigo
This is very intriguing, good work.  ;)
I'll have to come back and re-read it again several times, some of it "resonates" with other things I'm familiar from elsewhere. Then perhaps we can start a discussion on the subject...
Koen1
Yes this is interesting,
and extremely similar to the "technology" of David Hamel...
Hamel also linked a lot of ancient Egyptian depictions to scientific
concepts, was also fascinated by the Egyptian Djed pillars,
the baboons, the magnetic granite pillars of Egypt, etc.
He even wrote the book "the Granite man and the Butterfly" to try and
describe the visions he had as to how this was supposed to work,
and spent the past 10 years slowly constructing parst of his
granite plated, permanent magnet driven "antigrav" ship based
totally on those insights... His prototype magnetic "engine" device
was claimed to have started self-running, then whenit came up to speed
became surrounded in an electric blue aura, and at some point ripped
itself loose from the bolts with which it had been attached to the floor
and shot off straight through the roof never o be seen again.
Or so the story goes. ;)
Anyway, interesting stuff, perhaps you could post the source?
Rocr
I'd appreciate that amigo
I'm looking to spark some creative theories among the tech savy people here to flesh out and correct the concept .
I basically just had a kind of revelation back in the 80's and the supporting information just keeps adding to the whole concept of tapping the plasma sphere ..
Take the forth illustration look at the base it looks like some type of resister to me and that makes sense if the crystal needs to be charged and the observation of the burned appearance of the hands reported by Brown fits this line of thinking .
The English word  Pyramid evolved from the Greek word Pyramis or the plural Pyramidos and the root  Pyr in Greek was originally Pur and pronounced Pyr which means Fire .
And that would also fit the description of something which was drawing down this Energy from "Heaven" as describes by the Egyptians .
The descriptive phrase "Pyramids of Light" has long been part of our worlds cultures and is seen in art and described in thousands of ways . but what is the true origin of this concept ?
A device such as this drawing down a high energy stream from the virtually limitless pool that surrounds us and is replenished by the sun constantly Is IMHO the source of this constantly repeated theme .
It would light up the skies for hundreds of miles in all directions .
How did I first make this connection ? It was NASA's release of the fact that a volcano on IO had a continuous stream of "lightning" flowing into it and that this was the product of the immense gravitational anomaly that the volcano's sheer size created .
Well isn't that exactly what you would have here ? ..  if the exotic field generated by this crystal was amplified and the entire structure became resonant with the crystal and the properties were taken on by the entire structure ?
You would have the equivalent effect .
This anomaly would interact with the EM fields of the Earth itself  ...
QuoteThe volcano story is . . . required only because electrical
discharge effects are denied by astronomers. What kind of volcano
has a vent that glows at the temperature of a lightning arc? It
was described as the hottest spot in the solar system apart from
the solar photosphere!
NASA:
The Io torus, which is five times larger than Jupiter, glows with
a power greater than all the electricity generated on Earth, he
said.
This is an Electric Universe after all .
Come on science guys throw me a bone .. I'm starting to feel like a Daniel Jackson here
can I clear a room or what ;D
You guys want over unity right ?... Well....
Rocr
And Thank you for the tip  Koen  ..I'll start researching David Hamel right now
To bad he died in September 2007 i'd have loved to speak to him about this ..
