SM expose'
Started by HEYDUDE, August 02, 2008, 10:44:58 AM
ramset
Nice post and comments on DP fellows.....  Nice posts   Chet
Thanks Grandma
sirmikey1
Quote from: TheOne on August 26, 2008, 06:24:30 PM
I have 25' of flexible copper tube of 5/16", do you thing this could do the job?
Or the brass rod need to be filled with copper?
TheOne
  Use brass rod for best results.
innovation_station
i made a mod to the last unit i displayed
my pic says enough
ist
sirmikey1
THEONE,
   I was wrong about wrapping the brass rods.
Read Lorrie's NEW comments in the video, that you
do need to insulate the entire rod.
http://www.youtube.com/watch?v=Kdup42Epq0o
Mike
wattsup
@IS
Why so much magging around?
The more mag, the more energy you need to displace it, the bigger the primary coil will have to be.
I think we will need a new scale for magnetism, one being the gracious Tesla and two being a "persistence" scale for magnets. I would call persistence, the ability of the magnet to hold its flux vector against an opposing flux discharge.
On a scale form 1-10, 1 being the lowest persistence and 10 being the highest persistence, I would give your last photo a 7. Way to many magnets.
So here is what I mean.
If you had four magnets all made of the same material.
A: 1 Tesla with a volume of 4 cubic inches
B: 1/2 Tesla with a volume of 8 cubic inches
C: 1 Tesla with a volume of 1 cubic inch
D: 1/2 Tesla with a volume of 4 cubic inches
Placing them in order of persistence, from lowest to highest, I would say B - D - A - C.
If you "manage" to displace a persistent flux field, don't forget, it comes back free.
Those small round button Neos are damn persistent. I doubt if you can get a coil to displace it. They will just lock any potential for movement.
The other ones you are using are less powerful but you have too many around that coil.
Or at least you need to add spacers between the magnets and the coils. Some dielectric material.
But here is what I think will work. First, just get rid of the magnets and use only the secondary coil.
When you look at the original microwave transformer, or any other standard transformer, we have to understand that the energy transfer is not happening from the outside. It is happening from the center core portion. The outer part of the core is only making the field turn on itself, but the transfer happens from the center.
So I designed this insert that will fit inside the coil center.
This design replicates Handyguys' Thingamajigger without using any movement. We already know that moving his magnet, just up and down, with North on one side and South on the other side is producing overunity at the very low Hz he was using. Imagine doing this at very fast cycles. The design below is a dual-decker with both layers having the same North and South ends but the pulsing alternates between the red and green to simulate the up and down movement of the magnet field. That's it.
The core material for the insert can be wood or any other non-magnetic material. I would think that 10 turns of 18 awg per small coil is enough. The wind should be continuous from one coil to the next per layer end.
wattsup
