SM expose'
Started by HEYDUDE, August 02, 2008, 10:44:58 AM
innovation_station
@ whatsup im not shooting down any of your ideas ...
but you may be surprized .....how much this radiates.....
meaning when you strike the right freq that the massive feilds move easly  and at a distance from the source i do not claim any of my expairments to be correct they are my illusion .....
i get the same results with or with out the magnets as for the kick or flyback or re or bemf ok soooo
the magnets are not used to produce the original effect but to accelerate it   all that i have shown is only part of the whole you want to use the magnets as a generator.....  there for you need a  generator coil ....  wich my kicks will be sent through after conversion  and that engery will be accelerated  b4 it does the work
does this make any sence to anyone??
ist
sirmikey1
Hello,
What are the two terms used when using sound to:
1. produce electricity
2. produce mechanical movement or levitation
(not necessarily magnets/steel). Acoustic levitation/projection?
http://www.youtube.com/watch?v=94KzmB2bI7s
I am familiar with the terms "thermoacoustics", "sonofusion".
Many Thanks,
Smikey
gyulasun
1)  maybe    acoustic wave transducer  ?
for 2) I don't know   :(
Edit:  or it is good for both
sirmikey1
Hi group,
   I've been thinking about this all day, and I am feeling fairly certain
that the new witricity (wireless electricity) devices, when combined
as one, not wireless, may be the secret to the
Steven Marks Solid State Generator "Technology"
  Think about it, it's a device that merely transmits wireless alternating magnetic
field to a remote receiver coil.  Combine and make portable the entire device as one,
and you've got 120v SM-like, right?
witrictity: http://www.youtube.com/watch?v=CH6U1eyrsHY
Right?
SirMikey1
wattsup
@IS
Look at this.
I took a coil from a small (well not that small - actually pretty fat format) 110vac fan motor, and by chance I tried to put my ferrite core bucking coil inside and it fit. lol
To my surprise, with just 4 manual pulses of 12vdc on the bucking coil, I got 46vdc in my cap tank off the coil.
This is very good action because this what I would call very pure transfer. Not like the dead stuff I see more often then not in my testing. This is something special and it touches upon my previous post of putting the primary inside the secondary. By putting it inside, when you pulse, there is no where else it can go but outwards into the secondary. The bucking coil is also providing one half side north, other half side, just as in the above. Plus I think the ferrite is making like a "weak" magnet, getting saturated only to the point where the primary pulse can move it around, again inside the secondary..
Now to put it in an @allcanadian circuit since I now have a good primary-secondary. I will also try it on my Erfinder circuit instead on my big bulky microwave transformer.
Removing the coil was a snap. Just drill the rivet heads and bingo, you have a nice coil in hand. lol
Added:
For others who are doing such testing on many coil types, I usually use the same testing method on most all my set-ups when I start so each change is noticeable because you are always comparing it to a known base performance. So it is good for you to set-up a standard testing method that you can use on all coils. Mine is mostly manual pulsing dc on the input side and putting a diode and big capacitor on the output side and measure voltage rise off that capacitor. I have tested quickly so many things in this manner and can therefore know when something is reacting much more then I would expect. Just to say it is not that hard to try and the more people that test things, the better chance we have of finding those with interesting results.
