SM expose'
Started by HEYDUDE, August 02, 2008, 10:44:58 AM
innovation_station
Quote from: giantkiller on August 28, 2008, 04:18:36 PM
But your center coils have to have horizontal windings. 90 degrees to the flux. Like strumming a violin string.
Where did you get the controller? How many windings on the perimeter coils?
--giantkiller.
bro my coils get 2 more windings yet... 1 90 deg to the 1 there also copper same gage the other garden wire  same 90 deg to the 1 coil they are hooked up as follows
hor primary wind then vert primary wind then steel vert wind all 1 wire in that order pos goes to copper neg to steel wire all 15 coils will be wound this way
the controller was a kit i will fetch the link i want to mod the controls from what they are this mod is ESSANCITAL for out put with use with the coil i have showen
this unit will also use a freq gen tunned to 1 freq that should be fed to the controller  the controller will switch   that freq  to the coils in sequience as to cause rotation the bemf will be uitalized from all 15 coils as well rotation is free so it the generated power from my collector and my 2 pancakes hummmmm :o :o 8)
i also want to mod the controller curcuit so i can speed up the rotation thus increaseing out put from the generator part of this unit the kicks are deturminied by the freq genny (set to the resonant freq of all the kick coils ) ;)
PLUSE IT.... COLLECT IT .......ROTATE IT.....   USE IT!!!!
IST
innovation_station
oops forgot to mention there 100 turns on my 15 coils hor wind
the vertical wind im not sure gonna fill the tube
ist
tube mesures 2 3/8" across and 3.25" tall
TheOne
Quote from: sirmikey1 on August 26, 2008, 07:23:42 PM
TheOne
  Use brass rod for best results.
I found my problem, the stainless steel rod work and my #18 also work, my problem was the fullwave bridge rectifier, I forget this important piece lol.
I get from the wall socket around 20v, and from my inverter around 16v, I cannot tell about the amp yet but I can light up one led (not a full intensity) but it work constantly.
I can probably charge batteries from that ROD.
orbs
I actually found it interesting that "inductive kick" is mentioned in The Keys of Enoch 302:26. Could it be that some of SM's ideas came from that book?
ramset
H D Ive seen you comment in other threads [on 911] I always thought it strange the amount of bad guys from Saudi Arabia [ flying the planes]
This helps explain a lot http://www.youtube.com/watch?v=IYPjGn-hP8A&feature=related
Also design news www.designnews.com  august issue [EVERY CAR MANU HAS SOMETHING on the road or in the garauge that runs on water]
Chet
Thanks Grandma
