Some questions about Electric Vehicle
Started by Magnethos, August 03, 2008, 06:33:31 PM
TheOne
Quote from: Magnethos on August 06, 2008, 08:39:52 AM
Thanks for your replies.
Well I said that I think my car is 100 HP. But I want to start the project with the microcar because it requires less energy.
I won't use batteries, of course. They are very heavy and expensive.
I asked that because I'm building an electromagnetic engine. Now, I can run a bedini motor without batteries, I'm building a device to supply energy to the bedini motor. I don't know where the energy comes from, but I'm able to run a bedini motor without batteries.
Electric car don't need 100HP, in fact only 20HP will do like a 130HP, since motor lose a lot of energy in heat, most of the power is wasted.
All DIY electric car usually use 20HP to 40HP motor, very good motor here -> http://www.go-ev.com/images/002_07_ImPulse_9_Sales_Sheet.pdf
ramset
Magnethus  early VW 36 hp    ICE very low efficiency   electric motor much higher efficiency would not surprise me 10hp electric [or less] drives early VW like ICE  Chet PS did you know magnacoaster?
Thanks Grandma
Shanti
QuoteElectric car don't need 100HP, in fact only 20HP will do like a 130HP, since motor lose a lot of energy in heat, most of the power is wasted.
QuoteICE very low efficiency   electric motor much higher efficiency would not surprise me 10hp electric [or less] drives early VW like ICE
Lol, what a bs! The hp indicated of an ICE, is the effective motive power of the motor.
Sure you can run a car with a smaller motor, and you can easily calculate what will be your max speed with it.
But then you could also take a smaller ICE. The problem then is, you will not have much accelleration force anymore, when already driving with some speed. If you can live with that, you can take a smaller engine.
But usually small electric cars, have a very leightweight design. And this car, was designed for an ICE. So it's not that lightweight as it could be. But anyway, you can convert anything, you just have to tell, how far do you wanna be able to drive with this thing, how fast you wanna be able to drive this thing, and how much accelleration force you actually still want to have to get there...The rest is simple math...
Magnethos
One more question...
Can a Bedini motor run with 2 or 3 miliAmps?
ramset
 SHANTI "Lol, what a bs! The hp indicated of an ICE, is the effective motive power of the motor SHANTI " sounds like something got lost in the translation ? you are saying the same thing just more words  Chet
Thanks Grandma
