I want a Newman machine
Started by cafeinst, August 14, 2008, 12:02:24 PM
Michelinho
The Newman motor theory formula:
E=mc2 (L)
L is the coil.
Work with this formula.
Michel
willitwork
Hi cafeinst,
Your question about skeptics made me look in the mirror for a bit. Here are my reservations about the Newman Motor. Some of them are emotional.
It feels like Newman can't be trusted. That's emotional I know, but it does feel that way.
Mr Biss diary of his dealings with Newman are, I think really telling. Stephan has been in touch with Mr Biss and would disagree with me. This is also an emotional response on my part.
As soon as I saw the Newman machine on Youtube I started looking for a wire and bearing supplier. It seemed that this machine is the real deal. But the nagging question would not go away. If this thing really gives that much extra energy, (or power or whatever) how come none of the Youtube builders ever made a self runner? How come Newman hasn't? I will ask that question again: How come Newman hasn't? If you can turn a several hundred pound shaft with a pack of small batteries you MUST be able to take power from that shaft to replace the batteries. It would take much less time to convert a "working" Newman into a self runner than it does to build the Newman itself.
The self runner issue is important because of the claims made about it. Many OU type devices claim to pull only small amounts of power from the vacuum or wherever. There is a need to investigate these, understand where and how the gain occurs and exploit it. With the Newman we constantly hear claims exceeding 10 times more out than in. Creating a self runner should be a no brainer.
I think Newman himself believes his own press. That may be why less cynical people than I are drawn to him.
bogchiblaster
Quote from: willitwork on August 19, 2008, 04:43:38 AM
Hi cafeinst,
Hello willitwork!
I share the same sentiment. Although I like fiddling with the Newman machine and I share as much optimism to make it work more efficiently as much as the super techno enthusiasts here like Stefan and the others, I really don't trust Mr. Newman.. Honestly.
You could say that I have more faith in the other YouTUbe guys like ray0energy, STARK, kmarinas, zeropointprophet who do the Newman machine, and at the same time show unbiased information at the results that they're getting (be it good or bad results), instead of claiming unlimited speed and power that the original inventor is doing.
Michelinho
Hint:
If you are using low potential, you are not running a Newman motor. You are running a magnetic motor.
A Newman Motor uses HIGH VOLTAGE.
The motor will turn like a Newman motor but it is NOT using the "Newman Effect". E=MC2 (L)
Michel
willitwork
G'day Michel,
Can you send me a link or some further detail on the "Newman Effect. E=MC2 (L)"?
I have definitely been viewing this through low voltage eyes.
thanks
