Electromagnet power transfer question.
Started by nwman, August 20, 2008, 12:35:51 AM
bobo36us2
@ Tim,
You may have already seen this, but there may be some useful
information for you here: http://free-energy-info.co.uk/Chapter3.pdf
nwman
Quote from: bobo36us2 on August 23, 2008, 09:03:52 PM
@ Tim,
Hi, I checked it out but most of it is hypothetical. And the ones that say they do work but only in a lab or with special materials are probably scams. If it works at all in a lab or anywhere the science world would be turned on its head. That's another topic though. There is some ideas I hadn't heard of and some really close to what I'm working on but that document only "talks" about them and doesn't really explain how they work.
Tim
nwman
I'm still looking into all the factors that this involves and I was just wondering if I could get more input on a few of the variable?
Is there certain shapes of magnetic cores that are more efficient? For example, do magnetic fields travel better through a curve or a sharp 90 degree angle or both equally?
In config4, I just want to double check that by simple turning the wire in opposite direction on C and D will combine the two poles to produce one pulse in the output coil?
I would assume it would be better to have the core be as small as possible to reduce resistance? Would I potentially run into problems if the input [primary] coil is right next to [but divided] the output [secondary] coil, or should I given them a little space?
I'm still a little fuzzy with the "flyback" concept. Does a simple transformer have flyback?
Is there actually a way to capture flyback that's tested and true and used in everyday technology?
Thanks,
Tim
gyulasun
Quote from: nwman on August 24, 2008, 03:49:32 PM
Thanks,
Tim
Hi,  this seems ok:
1) http://en.wikipedia.org/wiki/Flyback_converter
2) http://www.dos4ever.com/flyback/flyback.html
Gyula
nwman
Thanks Gyula,
Those links helped. I have no idea how to do the math but I feel a little more confident in the idea. If I understand it right the flyback shouldn't effect the over idea of my design but could be adapted to improve over all functionality?
Any opinions about my other questions?
Tim
