New free energy
Started by Energiasinfin, August 29, 2008, 02:03:36 PM
Energiasinfin
"AbbaRue"
It is true that the pressure increases with the depth or the height of the column of fluid. But the air pressure in the atmosphere is equal to 1 atm. That's why, which invested in a glass water does not fill the liquid. This team works in his right side, as a succession of "diving bells."
In addition, the hydraulic pressure input is equal to the output. The imbalance is given by the thrust of the column on the right side.
Again, sorry for my English.
Greetings,
shruggedatlas
Quote from: Energiasinfin on August 29, 2008, 02:03:36 PM
Hello. I want to introduce a device capable of generating unlimited energy, cleaner and safer. It operates under the principle of Arquimedes push for flotation. Only with air and water, without consumption of either. A detailed description, along with drawings and an animation may see in:
http://motiveandpneumaticenergyproducer.blogspot.com/
I am open to the general public, so that it can be used and modified freely, since it declared unpatentable. Therefore, I need a good spread of it to prevent anyone from taking him on an exclusive basis.
Thank you very much and I hope her comments,
Froilan Salaya
I think what you will find is that there is not enough power to eject the water, and the process will stop.
mscoffman
Quote from: Energiasinfin on August 30, 2008, 11:03:03 AM
MarkSCoffman
It's a good idea to use liquid heavier than water. We must take into account the law of Boyle on the compressibility of gases that rise in the drawers.
Greetings,
By the way, There are three additional things you can eventually look into;
#1 A vacuum is lighter than air. #2 a mechanical latch can be used remove
of compressibility issues. #3 A "free piston" design is possible.
You do have to remember three things. #1 an object is buoyed up by the weight of the fluid it displaces
at the surface  - but it gets compressed by the weight of the fluid column @ height. #2 to get buoyed
up, a force needs to work upward from below the object. #3 For work to be done something must move.
:S:MarkSCoffman
JSHYDROXY
cOMPLETELY OFF TOPIC !!!!
CAN SOMEBODY PLEEEEASE RECOMEND A GOOD QUALITY OSCILISCOPE  FOR EXPERIMENTERS LIKE US???
nitinnun
the pleiadians have said that the pyramid, is the easiest way to get electricity.
at least if it is on a planet. where it can harvest the planets clockwise spin from the air, and the planets counterclockwise spin from the ground.
