Electrinium
Started by singerxyz, September 02, 2008, 05:41:20 AM
Drannom
so let's go with Sodium Cyanide or with old silver battery, i was talking about iron-silver battery and i may be wrong, i do not know their name, the iron-silver compound is the result of the discharged battery
here the master Summera
QuoteThroughout this past century millions of storage batteries have been made of a great variety of materials and many of these old worn out batteries contain in the bottom of the case a sludge that is pure Electrinium Compound.
so what was the exact name of the battery he is talking about ?
Master in alum pyramid growing crystals at http://youtube.com/user/Cristallerie
resonanceman
Quote from: Drannom on October 12, 2008, 08:11:26 PM
he seems to be talking about all of them
But he also  says that  the  elements in the  electinium must all  be in harmony   so most  of the  batterys are probably  not  usable .........
I do think  you  had a point  when you said OLD silver battery ......the  battery industry   looks to  have become  a little to standardized .
gary
gary
resonanceman
If we could find a worn out Silver-Iron battery there would be enough Silver-
Iron compound in its bottom to make many Electrinium Units. Or, let us build a small storage battery
and compound our own Silver-Iron molecules through the discharge-charge process. The battery
need not be large. Four sheets of Silver, size three inches by four for the positive side, five sheets
of Iron for the negative using lead terminals for each side.
He says  IF  we could find  a worn out Silver-Iron battery
then he  goes on  explaining  how to  make one.
gary
Drannom
Resonanceman
from my point of view you are right, a lot of them are ok, the good one will get iron-silver compound as the result of discharging the battery (i suppose?)
2 easy way to get the iron-silver compound, the most sure should be with the Sodium Cyanide method
so i will go to sleep, and may be tomorrow we will find some Sodium Cyanide easily, or with great luck and old silver battery
good night
Drannom
Quote from: resonanceman on October 12, 2008, 09:03:03 PM
gary
yes, thank you Resonanceman, so now let's create a silver-iron battery !
with many heads there are much more ideas to understand the electrinium better
:D
