Towards Realizing the TPU
Started by poynt99, September 03, 2008, 08:46:35 PM
0 Members and 37 Guests are viewing this topic.
Room3327
Marco,
      It is not me you are saying has nothing, You are saying Tesla has nothing.  This isn't my idea!  I am merely trying to get to the bottom of what Tesla's idea's were.  What are you trying to do?
P.S.  I'm not saying the magnetic field is rotating per se,  Not me but Tesla says that it is the 2 points of highest magnetic intensity that are rotating.
giantkiller
Quote from: wattsup on January 24, 2009, 11:08:11 AM
@GK
I will get the Keely book. I am due for a good sofa read.
You will not able to rest, my friend.
@all,
Statement made of Intrtoductory pulse. Can you say 'Magnet swipe'?
Quick, you won't be sorry...
Page 134, 2nd column, top paragraph:
http://www.overunity.com/index.php?action=tpmod;dl=get218
Now we have reference to this action by Keely, Telsa, Steven Mark of kicking in the resonance. And then what is mentioned? You can transmit very large power through resonance. And the transmitting device is fed by the Resonant coupling with the universe properties.
Most here are taught by Dominant Current layer. There are 2 more layers for all this TPU topology, Tesla and Keely to be understood. This is what is hidden in the Tesal patents and clearly spelled out by Keely.
And did you know Keely and Cayce had meetings over the benefits of SVP in health issues(Dotto ring)? Keely could touch things and make them work. Cayce could touch bodies and diagnose them. Pomerlou could think frequencies and make coils ring.
http://peswiki.com/index.php/Directory:Daniel_Pomerleau_Free_Energy_Coils
@Marco,
you are right. Same old psychology in these threads. Alot of Edisons have come and gone. Some still hold onto old school. That is too bad.
--giantkiller.
Hoppy
@ wattsup wrote: -
"Then there is the most puzzling side. I once did a test using the FTPU outer rings, coil as primary and ring as output secondary. The primary was connected to a Tesla ozone patent set-up so the outer ring coil was the primary of the working circuit. This actually gave the best coupling effect I have seen in any of my tests. But here is the question. To do this you need a coil of high induction and where in the FTPU could you see such a coil. It's not the outer coils or rings, it's not the center toroid, so where? It could be the one hidden on the lower disk or it could be placed inside the center of the reel structure since we see there is something there when he turns it over. I thought it looked like a microphone to induce high frequency audio feedback."
The coil of high induction has to be the one with most turns. Remember what SM said about cutting as many copper wires as possible with magnetic flux. I would say this is the outer coil but this must be bifilar, very high inductance and not connected to anything at each end (ends left floating). I would connect the two strands in Tesla series (end of one winding connected to the start of the other winding). The collector would then be a number of turns of heavy copper wire ( very low inductance coil) in close proximity to the bifilar coil. The high inductance bifilar coil might be made of iron wire? I would say that the toroids are HV generator to pulse a control coil, again wound in close proximity to the other two coils. The open bifilar should have the effect of boosting the coupling between the collector and the control coil and. The whole unit should find its own natural resonance and tune itself to the load, so long as the bifilar coil is left open ended.
I see no precision in the construction of SM's TPU's. In fact the build looks quite sloppy, so I do not see why we should assume any real critical aspects other than getting the coils in very close proximity to each other. I can see that there may well be three groups three coils around the circumference of the big TPU to increase power output and these may be working at different frequencies but not necessarily creating a rotating magnetic field.
Hoppy
turbo
Quote from: Room3327 on January 24, 2009, 01:27:31 PM
Marco,
First of all i'm not saying that Tesla had nothing, these are your words.
Tesla knew how to make things work but he never figured out why they did what they did.
Please get to that bottom of what Tesla's idea's were ,maybe you will find out he was a clever normal person who discoverd alot of things, but he wasn't a god.
He also made alot of mistakes ,which is human.
I am fighting an endless battle in the hope it will end one day.
wattsup
@Room3327
I thought  you were referring to the rotational speed of the generator in the Tesla patent.
@sparks
I think I got exactly what you mean. Surprised?
The FTPU has a second ring coil and that explains why the winding wires had certain changes in their visual diameters when  looking real close up. The outer ring is the output converter coil and now to only make high voltage spikes, that's easy. The outputs I have already traced.
Holly shit. Next experiments. Another insulated bailing wire ring with one thin wind and one thicker wind.
