Peltier Generating More Watts Than A Solar Panel
Started by billmehess, September 11, 2008, 06:04:39 PM
crazyoldfart
I believe you said you had your meter in parallel with the peltier. that could have added as a load with the peltier and given you a false reading. the proper way to measure a load is inline (series) . try your measurement again with this configuration and let me know your results.
abbhawk
I know this is a old discussion and im not sure what to say - people convince guy started discussion that he is wrong - are YOU sure he IS wrong?
It IS 10 years later now and might be a coincedence but try look at this peltier element from Alibaba which look alot like the one mentioned in here.
https://www.alibaba.com/product-detail/TES1-12703-12V-3A-36W-30x30mm_1126728147.html?spm=a2700.7724838.2017115.53.3c572d3046jTzG
One element is 3x3cm and have output of 12v x 3A= 36watt
If you have 1 m2 = 1000cm2/9cm2= 111,11 elements per m2 x 36watt = 4000,00 watt
So it is actually true, and price is 2,78dollar x 111 = 310 dollar of peltiers to make a 4kwh output. Just remember that these 4000watt is calculated at 1A, my house use more like 8A - so 1 m2 equals more like 500 watt at 8A. So if you have sun like 8 hours a day, 1 m2 make 4kwh and you probably need like 5 m2 to make 20kwh daily which is what i use.
Do you agree???
ramset
Hmmm
Quote from the supplier
The cooling piece of high-power general models, Entering by a misunderstanding, that the power the greater the cooling, the better it is not true Key depends on what your use, if you do not understand or did not used - not to purchase
If it is fun, and we do not recommend high-power,
end quote
seems like one long disclaimer
However I must say
pretty cool claim...to big to pass up [just in case ?
will see if one of the member Labs can check this and post results here.
thanks for the heads up...
abbhawk
Your not a peltier salesman are you?? [only kidding....
respectfully
Chet K
Thanks Grandma
blueplanet
Why care?
Just experiment it to find out.
Quote from: ramset on February 25, 2018, 08:46:22 AM
Hmmm
end quote
However I must say
abbhawk
respectfully
Chet K
ramset
blueplanet
Yes
Glad you were paying attention .....[or were you??
Chet K
Thanks Grandma
