The Road to Perpetual Motion
Started by hansvonlieven, September 12, 2008, 02:32:15 PM
WilbyInebriated
awful quiet in here, must be the sound of progress   ;)
listen to what spinner, marctwo, kator, etc. are saying, give up this "pissmobile" you are working on. listen to pirate and save yourself from going down this dead end street.
you might find this interesting though, a "believers" collectible, the souvenir of a delusion.
http://www.goantiques.com/detail,keely-motor-company,340306.html
hansvonlieven
G'day Spinner and all,
Let me say first of all that I like your reply to my propositions, it is well reasoned and eloquently put. This is the kind of response I was hoping for when I wrote my original paper.
I agree with you that my simulations are not as convincing as they could be. I am now working on a better experimental setup to prove my theorem. The limitations of WM2D are such that the programme is just about useless for a more convincing demo.
If my theories are correct and if there is a discrepancy between input and output energy this discrepancy should grow with increased speed.
Gravity as input energy is obviously out of the question as the maximum speed I can reach is limited by the laws that govern free fall.
To set up a proper experiment the wheel would need to rotate at about between 10,000 and 20,000 rpm. At these kind of velocities the CF is enormous and if there is any detrimental effect on the wheel this should show up dramatically.
I have a tentative design at the moment but I need to come up with a less complex approach since the building of that particular device is beyond my resources.
I am working on this right now and I shall keep you informed of any progress or failure as the case may be.
Unfortunately there are only 24 hours in a day and available time is limited.
Thanks for your input.
Hans von Lieven
Marctwo
Hans, why is it that you came to think that this extra energy is being produced in the first place?
Are you perhaps just overlooking the relative differences in the various reference frames used to describe these 'forces'?
hansvonlieven
G'day Mark,
One of the reasons is that I have worked with centrifugal casting machines that use centrifugal clamping devices to clamp the molds. There are huge pressures that these clamps generate without using any extra power.
Just one application
Hans von Lieven
ashtweth_nihilisti
Know and Understand Centrifugal Pumps
Very few industrial pumps come out of service and go into the maintenance shop because the volute casing or impeller split down the middle, or because the shaft fractured into four pieces. The majority of pumps go into the shop because the bearings or the mechanical seal failed. Most mechanics spend their time at work time greasing and changing bearings, changing pump packing, and mechanical seals. The mechanical engineers spend their time comparing the various claims of the pump manufacturers, trying desperately to relate the theory learned at the University with the reality of the industrial plant. Purchasing agents have to make costly decisions with inadequate information at their disposal. Process engineers and operators are charged with maintaining and increasing production. The focus of industrial plant maintenance has always been that the design is correct, and that the operation of the pumps in the system is as it should be. In this book, you will see that in the majority of occasions, this is not
true. Most of us in maintenance spend our valuable time, just changing parts, and in the best of cases, performing preventive maintenance, trying to diminish the time required to change those parts.
We almost never stop to consider what is causing the continual failure of this equipment. This book will help you to step away from the fireman approach, of putting out fires and chasing emergencies. This book is directed toward the understanding of industrial pumps and their systems. It won’t be a guide on how to correctly design pumps, nor how to rebuild and repair pumps. There are existing books and courses directed toward those themes. By understanding the real reasons for pump failure, analyzing those failures, and diagnosing pump behavior through interpretation of pressure gauges, you can achieve productive pump operation and contain maintenance costs. This book will serve as a guide to STOP repairing industrial pumps.
Download
http://depositfiles.com/files/8487276
;D
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.panaceauniversity.org
http://www.geocities.com/glorybangla/cqtes.htm
