The Road to Perpetual Motion
Started by hansvonlieven, September 12, 2008, 02:32:15 PM
Kator01
Hans,
I forgot to mention in my last post that I made some calculation errors at that time and  I had stored in my mind a wrong formula of momentum.
But most important for your understanding  is the attwood-machine. Just only read this and test the simulation-software.
But the calculation-formulas are clear. Up to the point you will release the ball at the bottom-dead-point in your second simulation you will have two seperate systems with the energy split. No gain at that point.
This is the reason why pequaide then suggests that in a second step the left rotating mass must then be stopped by transfering all of its momentum to the ball ( of steel-spheres in his setup )
If this really works ? I do not know. There is a test-setup- I had in mind at that time, but he was reluctant to try it.
I mean I believe him that he has had succes to stop the rotating cylinder but I doubt the claim that there is an energy-gain with the spheres. It has to be tested
Kator
Pirate88179
@ Marctwo:
"This isn't about taking sides with someone because they have a good rep.  Or taking sides against conventional science because of the bumble bees.  This is about CF magically producing extra energy out of thin air."
Your above statement shows you have either not been reading what Hans has posted thus far, or you don't/can't/refuse to understand it.  Hans has never mentioned "magically", this is your word.  He is an engineer and the last thing an engineer relies on is "magic".
The bee story was just an illustration to demonstrate how far we have gone without actually knowing what is possible, and not possible.  Even Stephen Hawking has only a theory about gravity, probably the best one out there, but he admits we don't "know" what it is.  With basic fundamental information like this lacking in our sciences, I find it hard to believe absolutes based upon this same incomplete science.  No magic here I assure you.
hansvonlieven
@ kator,
I have had a look at the atwood machine simulation and at your calculations. The big question is what happens at really high velocities. So what if the energies are split if the centrifugal force component is part of it and that grows EXPONENTIALLY.
@ Bill,
Don't worry about gravity, its not there. Einstein said it is a fictitious force. That's why falling out of an aeroplane does not hurt you until you hit the ground. It's the ground that kills you not gravity.  :D  :D  :D
Hans von Lieven
Marctwo
@Bill:  Yes, magically was my choice of word... and I think it fits well.  Things that can't be explained by science have often been described as magic.
It doesn't matter what Stephen Hawking thinks about gravity... Hans' experiments show no extra energy created by CF.
spinner
Hi, Hans!
I like your professional approach to the question. It's good to see a systematic, intelligent and persistent work, backed up with a plain explanations, experiments, drawings. Very good!
Still I think it's very bold to switch from the particular device (alleged PM as this particular "Keenie's gravity wheel" design) to a general claims as >Why Overunity and therefore Perpetual Motion is possible.< Mind you, science  is based on a hundreeds of years old foundations, like clearing up the centuries long quest for "Perpetuum Mobile".
Von Helmholtz, Meyer and  Joule are considered as fathers of (modern) Energy law. Two medicine doctors and an enthusiastic experimentor. Science recognised, accepted (and "cleared" up (!)) their work. "Joule" became a basic energy unit, and both doctors acchievements are a classical science history.
One of a most popular quotes from Helmholtz's original paper (at least used by the 'FE' researchers) talks about the impossibility of perpetual motion which must be a consequence of some natural law which prevents it (CoE). (A centuries long search for a Perpetual Motion was not successful, therefore it must be some natural obstacle which prevents this from happening... ).
Fascinating, but a modern version says: Because of the Law of Conservation of Energy, "Perpetual Motion" is impossible... Hmm...?
Von Helmholtz was a brilliant man, but he couldn't be better in his reasoning than thousands of people which continued the work later. One of a more obvious misunderstandings was that he mixed up the concepts of force and energy (which were still fresh at his time!) (this is the most frequent mistake which tinkerers make nowadays, too...OK, together with the concept of "Power"..)
Which brings us to the question of "fictitious" forces - the ones present only in a moving frame of reference, The ones which "pop's out of nowhere",  like with a combination of e.g. linear/rotational ones..  CP/CF,Coriolis,.. Take a pendulum, as you've suggested... A rigid string connecting a pendulum weight/bob and the axle of rotation, in a gravity field...
The mechanics is known. A 'fictitious' force bulds up in the (linear) frame of reference of a connecting string. This force is there, it's "pumping" while the pendulum swings. The (connecting string) material is stressed with this Force (i'm sitting on a chair and pressing it with the gravity induced force right now, but - obviosly - i'm still not doing any "real" work......).
In an ideal environment, a pendulum would swing forever... (no losses - air, mech.  friction,etc). But, according to (modern) definitions of Energy, no work (energy) is done (if you look at the "fictitius" Centripetal Force) if there is no a change of position (in any observable "frame of reference"). A basic A=Fd (Work equals to Force times Displacement). A book sitting on a shelf, a magnet sticking on the fridge door, ,.. - they all produce Force but they're not "providing" the Work (or expendng the Energy)....
Now, try to use a CF/CP force - replace a "rigid" string of a pendulum with an ellastic one (spring) - the behaviour of such pendulum would be very different... A conservation of momentum (and all other known mechanical stuff) would kick in...
Point is - if you try to tap the "fictitious" CP force, it will be payed off with a "Conservation of Momentum/Energy" budget. One way or the other.
Part 2:
So, according to science that’s not really there either, it’s fictitious!
Fictitious forces and work
Fictitious forces can be considered to do work, provided that they move an object on a trajectory that changes its energy from potential to kinetic.
All fictitious forces are proportional to the mass of the object upon which they act, which is also true for gravity. This led Albert Einstein to wonder whether gravity was a fictitious force as well. He noted that a freefalling observer in a closed box would not be able to detect the force of gravity; hence, freefalling reference frames are equivalent to an inertial reference frame (the equivalence principle). Following up on this insight, Einstein was able to formulate a theory with gravity as a fictitious force; attributing the apparent acceleration of gravity to the curvature of spacetime. This idea underlies Einstein's theory of general relativity.
What this says is fascinating. On one hand they say it’s not really there and on the other hand they admit that is also a very real additional force that emerges independently of the forces involved that brought the prerequisite conditions about and can do work!
In other words FREE ENERGY!
So, why is science obscuring this fact with convoluted concepts and obscure language?
Simply put, the acceptance of these forces as real rattles the very foundation on which current scientific thinking is based.
If the forces are real that means either that the Conservation of Energy laws are wrong, because these forces manifest out of nowhere, which is believed impossible. This is not a premise science is prepared to accept and quite rightly so in my view.
The only remaining alternative is equally impalatable to science. It would mean that there is an underlying energy field that can exchange energy with the observable “reality”. In other words an ether (aether for the purist) of sorts.
So they are caught between a rock and a hard place and have to resort to this sort of crap because the existence of these forces is undeniable whether science can explain them or not.
Hmm, why all the hard questioning about the "Science"? What kind of crap "they" produced? Where are the real  facts opposing the "orthodox" views? Any solid, verifyable proofs?
If you're so sure about the "free energy", just do the experiments. Marctwo expressed some very reasonable concerns. And Kator's evaluations are "a must read". Pequade's ideas are intrigueing, indeed... It seems that a physical, real proof is all that is missing at the moment.....
I've looked at your "WM2D" videos. I'm not convinced, sorry.... What makes you think that a ball (after the release from the wheel would roll (slide?) up the incline? Because of a "tangential" momentum? What makes you think that this action is not payed with the reduced wheel momentum/energy?
By the time the ball stops at the top of the incline, the wheel is left with less kinetic energy than it was originally imparted by the ball dropping for a height "Z".  I just see the classical "mgh" stuff... Sorry.
You could make an incline in a spiral shape (to bring the ball back to the position near the wheel, where the ball could be picked up again)...
Or, a carefully "tuned" device consisting of two such wheels/balls/inclines, working in sinhronicity could work perpetually... With a little "luck", each ball would be picked up by opposite wheel, and lifted up and over into a new cycle... Or not...??
An undeniably Working Prototype would instantly clear all the misunderstandings...  Why the hell it never happens???
I hope you'll succede!
Cheers!
"Ex nihilo nihil"
