Otis Carr's flying machine and the Utron O.U. Electrical Accumulator !
Started by Reformator, September 22, 2008, 05:33:45 PM
storre
I read the story and came away with a completely different conclusion. To me it was just a way to discredit something that they need to discredit. The same thing they did to Carr during his moment is what they want to do to everyone that thinks what he did is possible. BTW, the picture is of a german built (build in brazil where I live) space craft. Obviously not from an advanced civilization but it worked even though it resembles the style of a 56 chevy which is the clue to it's build date.
I prefer to believe and I support that belief with the facts that many people came up with VERY similar solutions to solve the same problem.
Read this list of people that solved the problem of anti-gravity and see if you can see a common thread.
Decker's Anti-Gravity Correlatives - 03/23/97
After much consideration and discussion with trusted friends, the following heretofore private file is being posted in hopes it will help to accelerate the discovery of gravity control in a real sense. It does not matter who does it, just that it is available for use by everyone. Maybe others will find it useful.
Compiled over the years and written up on December 5, 1993
The following is a compilation of information pointing to the basic principle of levitation that I have found in years of collecting and analyzing levitation phenomena and which can be reduced to a basic set of "clues".
These correlations are more than sufficient to give us engineerable approaches to the diminution or complete negation of what we term "weight" and "gravity".
One should understand the complete fallacy regarding the Newtonian concept of gravity being an ATTRACTIVE force. Rather, the majority of evidence points to gravity being a PUSHING force, most clearly seen in the relationships of celestial bodies. The permutations associated with smaller aggregates make it more difficult to perceive the TRUE nature of "gravity".
The simplest approach to keep in mind is that the universe is full of pressure zones that flow toward the center of all masses at a velocity proportionate to the mass aggregate size. Such a flow can be thought of as a wind blowing into the planet, with the planet functioning as a screen on which all mass is held by this incoming pressure.
We and all other mass aggregations which are associated with a particular celestial body are thus held onto the planet by this wind. Overcoming it is then simply a matter of "coming to speed" with this incoming flow.
Levity Rings
1) Keely - uses two methods
For Thrust (or levitation)
An artificial neutral center is created which causes the natural neutral center of the test mass to be drawn towards the artificial center with an attraction proportional to the energy flowing through the artificial neutral center.
For Weight Increase or aggregation of additional mass
When the artificial neutral center is superposed onto the natural center, the aether flows increase proportionate to the entraining amplitudes flowing through the artificial neutral center thus causing an increase in weight and a gradual INCREASE in the mass density.
For Levitation
A wire or ring is placed around the object. The ring is fed with a frequency that resonates with the neutral center of the mass. Such a resonance, properly directed can cause what Keely calls "high vortex action" to decrease or increase the aether flow through the mass neutral center. This flow creates the equivalent of a soliton, or a self-contained standing wave with extremely high rotational velocities on the perimeter of the mass. Such a flow directly controls the "weight" of the mass by exceeding the Flotte 'Z' axis or better stated, by creating a higher potential in the mass aggregate than that of the surrounding media for ejection of the mass to one more favorable to its energetic level.
Keely also reports a cooling effect of the local air when the anti-grav effect was in operation.
2) Uncle - (my FAVORITE!!)
the old man claimed he had inherited the secret of antigravity from his late uncle. "Weight is no object to me," he said. "I suspend all gravity by placing a small wire around an object. Taken from an 1890 series airship contact case. This particular airship as in numerous other documented cases, FLOATED in the air as a ship FLOATS on water.
3) Dotto
a constantan RING, cooled and heated, creates a force like that which suspends the planets in their orbits. The velocity of energy within this ring exceeds that of the planet velocity, thus imparting a tremendous amount of energy within the space of the ring and thus providing "levitation".
4) Tesla
"I can place a ring around the Earth at the equator and move it anywhere I so wish." It is CLAIMED that Tesla built a levitating sphere comprised of a ball with a single ring at the equator. When this ring was fed with an alternating current at high potential, one half of the sphere became very hot, the other very cold. The sphere levitated to a height dependent on the energy applied.
5) Schappeller
a globe, the top half hot, the bottom half cold, will levitate. The globe was composed of an external sphere made of iron, with an internal sphere made of ceramic or other non-conductive, high temperature material. This internal sphere was grooved to make a path for two separate conductive copper tubes, wound in opposite directions, one for the top half, spinning from the "North" pole towards the equator, the other spinning from the "South" pole towards the equator. The copper tube was filled with a "polarized dielectric". When the center sphere was spun with the iron sphere remaining stationary, a "glowing magnetism" was produced that could be tapped to produce free energy and/or levitation.
6) Farrow
an 18 ounce box, with a ring of electrical interrupters, when powered will produce a negative "weight" of 3 ounces to cause the box to float in the air. These electrical interrupters when fired at a frequency related or equal to that of the mass aggregate frequency, will produce the rotating sphere of high potential that results in levitation or "weight loss"
Aggregate Resonance Levitation
7) Egyptian Meru
a rectangular stone is covered on 4 sides with wet papyrus. A specially carved wooden rod is struck against the uncovered stone face and removed. While holding the rod, the vibrations will continue to increase, at the greatest amplitude, the rod is re- applied to the exposed stone face. The energy from the rod will suffuse through the stone, alter the neutral center aether flow by stimulated kindling and cause temporary levitation.
8) Leekskalnin
the hands are placed lightly over a stone to be levitated. An orally produced musical scale is run through until the hands feel a response stimulus from the stone. Each tone must be sustained to allow the mass to resonate and produce a sufficient reflection to enable detection. Once the mass aggregate resonance is hit upon, that frequency must be SUSTAINED to cause the neutral center to alter the aether flow and thus cause the mass to levitate.
Mechanical Rotation
9) Carr
found that rotation of a ring at a velocity greater than that of the Earth at its equator will produce levitation. Although Carr does not explain WHY this is so (I have since found it in Flotte's 'Z' axis), it is again the control of the flow of Aether through the natural neutral center of the mass.
10) Maine Professor - courtesy of Dan Davidson
a mechanical system, possibly using uni-directional thrust to create a levitation effect. This could also be a rotational mass, using the principle of the Carr Velocity.
Vortexial Rotation
11) Brown
the Biefeld/Brown effect, IN ITS MOST ADVANCED FORM, using rotation of very high potentials on the skin of the craft to produce the artififical neutral center. Early experiments showed a correlation between high voltage charges and gravity. When these charges were rotated, the craft developed tremendous lift and thrust, as specified below.
12) Searl
the electrical and kinetic energies are resonantly coupled from high speed rotation. This rotation exceeds the Carr Velocity at the Earth's Equator and so interacts with the neutral center of the mass to affect the aether flow and produce levitation.
13) Schauberger
by rapid rotation of sand, air, water or any other medium in a vortexial pattern, the aether flow through the neutral center of a mass can be enhanced or retarded to produce levitation.
Artificial Neutral Center
14) Wil Wilson
anecdote about a newspaper article with a picture describing a levitation device that was suppressed. A cylindrical container with a series of solenoids mounted on the top of the cylinder. Each solenoid is pointed towards a central focal point. When the solenoids are pulsed at the same frequency, the combined force creates an artificial neutral center which, depending on the amplitude of energy flowing into this artificial neutral center will cause the natural mass neutral center to be attracted to the artificial neutral center. The mass will thus be pulled in which ever direction the artificial neutral center is pointed, regardless of direction.
15) Fry
from a UFO case history, description of two rings. When dual magnetic fields are produced in these rings, the interaction will focus between the rings. This focal point will produce an artificial neutral center towards which the mass will be attracted by virtue of resonant attraction of the natural neutral center.
Theoretical
16) Flotte
the late Engineer Leonard Flotte, wrote an excellent book refuting the Einstein principles of Relativity. He uses a helixial system to describe planetary rotation, how such forces could be tapped, the relationship to time, gravity and other correlates.
I have spoken to the son, who understands almost nothing of his fathers work beyond saying that yes, his father had refrained from stating certain aspects of his research in the published book.
Essentially, all planetary orbits can be mapped onto a cylinder of a fixed length. The orbit, though longer in some cases, shorter in others, simply spirals around the cylinder MORE times dependent on its length. Thus, a reference frame is established known as the 'Z' axis. This 'Z' axis is thus a measure of the rotation VELOCITY of a planetary mass aggregate, otherwise known as its orbit.
The orbit of each planet is an indication of the energy level associated with that REGION OF SPACE and clues us into how we can transcend time and gravity by EXCEEDING the 'Z' axis, i.e. accelerating the energy level of a mass to exceed the energy level for our particular location in space.
This correlates perfectly with Russell, Pawlicki and Nieper (among others) who state that the closer to the sun or other RADIANT bodies, the greater is the energy density for that region of space. Thus, the farther one moves FROM such a radiant body, the less energetic is the local environment.
All this points to equating levitation as spitting a wet watermelon seed, from one pressure zone (energy level) to another, based on the focussed energy level IN a mass neutral center.
Shanti
Lol, gee, there was somebody busy.
I agree, that the link you posted doesn't necessarily really prove it was scam.
Especially as the few more or less trustworthy people who really declared or even showed they built something in that direction all had the same physics! And from this physics point of view, Carr's device should work.
And from all these, I think Walter Russell explained at it's best the "physics" behind it.
@storre: About the many things you posted.
Well I only know very few of them. As I occupied myself intensively only with these people (Keely, Schauberger, Tesla, Carr, Schaeppeller, Russell). But for these few the explanantions given are definitely not really correct:
example:
Quote5) Schappeller
I don't know where to start. But for example he never said that the top is hot and the bottom cold.
Another example is the last sentence about the center sphere spun with a stationary iron sphere...Well his actual machine worked quite differently...
It is really amazing, so many people write so many wrong things about Schaeppeller. This astonishs me, as there is only one book to study. But even authors how wrote complete chapters in their books about Schaeppeller don't seem to have really read it! Surely it's difficult to get. But you can download it on the net. I personally have an original, as this is much easier to study than a scan...
Another example:
Quote9) Carr
The rotation is only an additional movement which is necessary for discharge, the important part is the Central-Utron!
Just spinning something will not get you anywhere...no matter how fast you spin...
Quote4) Tesla
When did he say that! Who claims this? I thought I read all of Teslas lectures and articles, but never read something about that!
This smells to me like another fantasy claim someone invented about Tesla...
Or another serious misinterpretation...like many many others...
I also not completely agree with the Keely and Schauberger explanations, but as these two anyway had a very very special vocabulary in explaining their work, it maybe wouldn't be easy to explain it in a few simple words...
To me it seems the author of these explanations did gather all he could find about the phenomena, but didn't really profoundly study the work of these people or just didn't understand them, as it seems he sometimes didn't even really get the keypoints.
storre
Quote from: Shanti on December 16, 2008, 06:17:41 PM
I would agree on that point!
The hot and cold statement may have been an analogy. Many times these inventors made statements when they were alive so as to not tip off others. Now that is not important but then it would have been.
I'm interested in Schappeller but have never read anything of his. You know of a good link that has a good collection of his stuff or a link to that book?
And I've been wondering something that maybe you can shed some light on. Is it possible that with a high enough ac frequency and voltage that the ring around a globe would work? I believe in what Carr said in that if you can spin an object at it's relative mass velocity then it will be immune to the gravitational effects of the body that IT is spinning on. IOW the earth. Well maybe that is what Tesla was referring to and it reminds me a bit of John Keely's work also even though he was doing more with audible vibrations as far as I'm aware. Either way the harmonics continue on forever so even if we are messing with lower frequencies, they should have an effect on higher frequencies according to the harmonic overtones.
Pirate88179
Quote from: storre on December 16, 2008, 08:28:41 PM
You are missing the point here on this one I think.  I have read many books on Tesla and his "ring around the world" was a mechanical device designed to utilize the earth's rotation for power or travel.  Think about it for a minute.  (Probably not possible to build, but maybe)  He said to erect a ring that sits above the ground at a certain height, mounted on pylons like a bridge.  Once built, If you are on one side of the globe, that ring wants to fall due to gravity.  If you are on the other side of the globe, same thing.  His ideas was, once built, to turn it loose from the pylons. It would then "hover" because it was being pulled toward the earth in all directions and could not fall to the earth due to its construction. (ring)  He then said that while the earth was turning at 1 rpd, covering many thousands of miles, that it could be used to generate power like a generator.  also, he envisioned that a person could get on the ring in NY and step off a little while later in France.  See?  Very forward thinking from a real genius.  I believe this could actually be done.  Very expensive though.
Shanti
Ahh thank you Bill.
So it again was what I already thought. A serious misinterpretation of one of Tesla's devices. I also don't know how people can interpret Tesla's statements sometimes in such a very very different way...
Seems people read just what they wanna read...Unfortunately this is the way the brain works...
Davson's book about Schappeller's physics: http://www.free-energy-info.co.uk/Davson.pdf
QuoteI believe in what Carr said in that if you can spin an object at it's relative mass velocity then it will be immune to the gravitational effects of the body that IT is spinning on.
Well this is not really completely correct. If you read "The Universal One", you will immediately understand what Carr talks about. If you want to understand this, you have to read it.
First you have to build an artificial atom/plant/solar/system/galaxy/etc..., this you mainly do with the help of the Central-Utron. Like that it becomes a natural system, which is able to "breathe" in and out. Now it also behaves like the rules for natural systems. And there now comes the rotation velocity into play. As the rotation velocity is directly proportional to the discharge of the system. If you just turn anytihing very fast you will not see any effect, as what you are turning is not an "artificial" breathing system. Otherwise there would be quite some things which would turn fast enough to levitate (e.g. a Turbomolecular pump), but they don't, simply because they are not in an artificial system, but still belong to the earth system....  The rotation velocity behaves mathematically exactly like Carr described. E.g. if you have a system which is 10 times smaller than the earth it has to turn 10times faster to get the same discharge as  the earth. this also determines the potential pressure of the system. So if you turn this system "relatively" as fast as the earth it will also float, like the earth in space.
An example: You never asked yourself, why the outer planets rotate so fast around themselves, while the inner planets rotate very slowly? This is exactly this law. The rotation period and the size are directly connected to the distance, where the systems are in equilibrium, and vice versa.
E.g. if you would grab the earth and put it at the distance where Jupiter is, it would become much bigger in size, would turn much faster around itself, and at the same time the revolution time around the sun would increase.
Sure this is just a rough explanation. As I said, if you want to have it more detailed, then you should read the book.
