Stanley Meyers Injector REVEALED
Started by sirmikey1, September 28, 2008, 10:29:11 AM
sparks
     Water is a liquid due to the size of the hydrogen atom compared to the oxygen atom.  The hydrogen proton reacts directly with the oxygen valence electrons.  This causes the molecule to be highly positive on the end with the hydrogen and negative on the end with the shifted electron valence orbitals.
This polarized molecule then forms intermolecular bonds which are responsible for not only water's high latent heat but for it's liquid properties at room temperature.  When the water is sparked as shown in these video's it explodes because the polarized intermolecular bonds are broken and we get steam.  This steam is not due to the breaking of the intermolecular polarized bonds normally accomplished by heat input to vibrate the water molecules apart but by working on the intermolecular bond electrically.  The steam molecules will immediately condense unless they are subjected to electrical or thermal agitation for that amount of time needed to propell the piston forward.   Myer injected an ionized gas to accomplish this.  Is this free energy or just a flash steam engine?
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
AhuraMazda
Quote from: sparks on October 04, 2008, 02:16:44 PM
The legend told is that Meyer drove his dune buggy across states only on water. I guess he had developed a flash overunity steam engine.
sparks
     There are similarities to what Myers did and believe it or not crop circles.
Microwave stimulation of hydrogen gas in the legs of a tetrahedron geometry are employed to do something to water.  Myers mixing chamber uses emwave reflection to further excite the mix in a resonant cavity. He also employs lazer excitation.  Upon compression of this mix I can see a rapid oxidation of water happening.
Think Legacy
Spread the Love
dankie
http://www.overunity.com/index.php?topic=5706.0
OK why dont all you idiot science dorks stfu with the stuff that you dont even understand but talk about as if you were some kind of engineer , give a little and give respect where its due , ME has figured out how the injector really works .Not with wild speculation and blabbering about EM waves that I read off some internet article, but with LOGIC.
This guy should have never quit school because all his concepts are total bullshit , you can pretty much a patent a brushless toothbrush if you wanted to.
sparks
    I was talking about Meyers mixing chamber.  He was using a highvoltage highfrequency resonant circuit whereby the chamber forms the capacitor in the circuit.  Very efficient use of electrical energy.  The voltage is used to produce emwave energy not current flow through the water vapor.  This whole deal works just like Tesla's ionizer.  Electrons exposed to a longitudinal emwave will seperate from the neucleus influence before the neucleus gets its ass in gear. This only happens when the voltage is high and the duty cycle low.  The electrons under their own power chase the wave.  While in unified motion their intrinsic kinetic energy is impressed on the external field.  The return of the electrons to natural orbitals is the most unified  flow and is responsible for the kick from a collapsing magnetic field.  Impulse energy.  Same goes on in his fuel cells.
Think Legacy
Spread the Love
