Gravity Mill - any comments to this idea?
Started by ooandioo, November 03, 2005, 06:13:20 AM
hartiberlin
Tbird, I can?t see the posting number on the PDA now, as it has a different browser surface. Will answer later, am pondering about the right parameters to get it right...
tbird
stefan,
i may not understand what you are talking about, but it sounds like you are drasticly changing the E.L.S.A. design.  so much so i think it would have to be covered elsewhere.  am i worng?
tbird
It's better to be thought a fool than to open your mouth and prove it!
hartiberlin
You are wrong TBird. Try to calculate your own example for the upward and sinking case and post it here, so we can see, if you already found the right solution. Many Thanks.
hartiberlin
Now lets extend my example to 0 to 20 Meters movement and let put the oscillation center point at 10 Meters deepth and calculate there the static case for equilibrium first...
hartiberlin
At 10 Meters deepth to have equilibrium and no movement, we need to have with the same dimensions as previously posted, we need an airvolume of 785,4 Liters at 2 bar and attached to it a weight of 785,4 Kg. Then this shuttle is not moving and just hovering at 10 meters deepth. Do you agree so far ?
