To be deleted
Started by nul-points, October 05, 2008, 10:23:18 AM
nul-points
hi all
i'm not aiming to start an ongoing thread here, because this result is part of my experiments with switched charge
   http://www.overunity.com/index.php?topic=4419.msg128942#msg128942
but i thought this was significant enough to give a heads-up to anyone whose tests involve recapturing fly-back energy from a coil
as i understand it, the official line on fly-back energy is that you only get back what you put in
the measurements i'm making on my switched-charge circuit show something different!
i'm pulse-charging a capacitor via a coil, and i also have a resistive load in series with them too
fly-back energy is returned to the RLC branch, after the pulse, via the diode at the positive end of the coil (see the negative portion of each Red trace)
the traces below - the first and last pulses in the switched-charge burst used to charge my output cap - show the applied pulse across the RLC branch (in Red) and the voltage across the 10 ohm resistor (in Blue)
you can see that, at the point that the pulses switch off, the current through the RLC branch was still rising, so the coil field is still being 'charged'
the traces clearly show that energy input to the RLC branch during the pulse is a fraction of the energy input which continues after the pulse stops
Energy input to the load for the first pulse:
57.6uJoules
  16.0uJ from the pulse
  41.6uJ from flyback
Energy input to the load for the last pulse:
20.2uJoules
  8.9uJ from the pulse
11.3uJ from flyback
the proportion of flyback energy to pulse energy reduced with each pulse between the first and last, as the stored voltage across the capacitor increased, but the ratio was always > 1
[this now gives further support to the overunity results i'm seeing on the switched-charge experiment - until now i couldn't see where the additional energy was entering the system - it appears that it's being supplied from the coil field collapse as flyback energy, extra to that supplied from the input capacitor]
some more details on test setup:-
my coil is approx 2.5mH, 0.5 ohm DC resistance, so the I^2*R loss in the coil is only 1/20th of the power developed across the load
pulse width as shown here is approx 77us, but this is not a critical value** - it's just an example
the first pulse peak-voltage shown is 8.3V approx (the initial voltage on my input cap) and the final pulse peak-voltage is 7.8V approx
**the pulse width could be increased until the RLC current, as monitored by the load resistor, maxes-out
(this assumes the core doesn't get saturated before this point)
any more width on the pulse, after that point, will not increase the coil field, it will just result in increasing energy lost in the coil thro' I^2*R loss
so, to achieve most benefit from flyback, the pulse width should always be less than the value which maxes-out the RLC current (or saturates the core)
Doc Ringwood's Free Energy site  http://ringcomps.co.uk/doc
turbo
Hi Nul-points  :)
I have seen similar behaviour.
You can put a variable capacitor over the coil for example like 10 to 500 pF.
Then you can tune the oscillation to certain frequencies.
If you place a pickup element near the coil ,like these things they used in old cassette players and video recorders, and you amplify the sound then you can actually listen to the collapse which has a verry familiar sound.
You can also use it to listen to permanent magnets.
Marco.
nul-points
hi Marco - interesting observation, thanks - i guess you're referring to the oscillations on the 'pulse' waveform (Red trace)
maybe i should make it clear that the energy gain is shown on the 'load' waveform (Blue trace)
the left-hand side of the triangle waveform (representing energy input pulse) is smaller than the right-hand side of the triangle waveform (representing additional energy gained from the flyback)
PS   i see the link to my switched-charge experiment thread didn't make it as an active link above
all the best
sandy
nul-points
thread title changed to clarify that these results show overunity flyback energy
260%  additional energy returned on first pulse
127%  additional energy returned on last pulse
all the best
sandy
forest
Please,if you have the circuit still, could you measure flyback energy when coil in your circuit is exactly inline with Earth magnetic field in N-S direction and then in E-W direction ?
