Sabous Magnet Motor
Started by CLaNZeR, October 06, 2008, 04:42:20 PM
nightlife
CLaNZeR, I agree and I too have seen that happen and that is why I try to bring up the threads topic at least every couple of postings as I did in my last post.
4Tesla
@Sean
So back to the threads topic.. do we have any more details of the build of this device?
Thanks,
Jason
Omega_0
Looks like a few variations on gravity-magnet combo.
So many of us are trying to find a sweet spot where the gravity pulls the wheel down and magnets restore it back to its starting position, which falls again.
These wheels (in pics) obviously don't seem to be working, but I'm not sure. And why would someone want to remain hidden with non working wheels ? Does he want to give an impression that he is hiding because he has working versions?
exnihiloest
Quote from: CLaNZeR on October 11, 2008, 07:10:25 PM
People post reasons why it will NOT work, like we are all idiots because we did not listen in science/physics Class while in school. The truth is we DID listen, but are still hoping something has been missed and may be discovered.
Hi Seans,
The problem is the wasted time in trying again and again wrong tracks in which many others have already failed. It is due to ignorance so people posting reasons why it will not work are right. Remember that nobody has yet presented an OU device that everybody can duplicate.
The typical example is magnetic (or gravitational) OU motors. It is a question of potentials. Magnets move to reduce their mutual magnetic potential energy. If there is no potential difference, they is nothing to let them move.
In order a system to be sustaining, it must be looped, i.e the initial and final positions must be the same to repeat the cycle. It follows the potential difference along a looped path is globally null, thus no OU can be expected: there is always a "sticky point" in a segment of a looped path with a potential gap equal (but with a reversed polarity) to the potential gap of the other section.
"It will NOT work" because there is no potential difference, or differently said, the work done does not depend on the path. You can imagine complicated setup with versatile path and many magnets, it will NOT work. It will not work except if...
Except if the main stream science is wrong and the work done by magnets is path dependant. In this case, complicated setups are not required. You just have to do precise measurements in basic experiments on the distances and forces applying to magnets when moving them carefully from one point to another using different paths, and then to compute the work.
I saw only one smart person (if I remember, he was an electronic engineer) who claimed that the work to separate two facing magnets was 10% less when pulling them away while keeping them facing than when sliding them away side by side. The only reason I did not try myself is because I estimated that his experimental setup was far outside a 10% precision but this guy applied the good method.
99% of OU magnet motor builders are not only wasting their time but also wasting the time of others by making stupid claims when they have nothing: "just the sticky point to pass and my motor will work" :-))). They mask the 1% of valuable people who suggest rational methods, point exactly the possible holes in the main stream science or would present a real duplicable proof of concept. And I do not even speak here about scams which add even more noise in FE energy.
The conclusion is that FE is not a question of blind faith or egocentric conviction but a question of imagination, reason and work. It can be done neither by neglecting all the actual scientific knowledge nor by reproducing by ignorance all the errors of the past. People who remind us "why it will not work" are essential and welcomed.
tinu
...or much shorter: PMMCNPW!
