Thanks to ALL for your help!!
Lets please use common sense.
Started by nightlife, October 06, 2008, 10:02:21 PM
nightlife
Michelinho,
QuoteWhat is common sense for you?
Common sense to me is what is commonly thought of by the average to make sense.
nightlife
GeoscienceStud, "Wind comes from higher pressure moving to replace lower pressure that occurs due to the air being heated from the sun (convection).  An energy input from the sun."
Lets talk about pressure for minute. What is pressure? What is heat?
They are both just a mass of vibrations that become what they are by being applied to a resistance. They both contain the other. Heat contains pressure and pressure contains heat because they are both the same and the only thing that makes them different is their vibrancy and or the resistance they encounter. You can not have pressure with out having heat and you can not have heat with out having a pressure.
Michelinho
@ marco,
Take a neodinium magnet before it is magnetized and after? What's the difference between the two? They are both the same but yet very different, one does work the other doesn't. A magnet is full of energy and it is kinetic.
@ nightlife,
Average for me is most of the people you see around that watch Fox news and believe everything said.
Take care,
Michel
turbo
Quote from: nightlife on October 08, 2008, 08:10:46 PM
-[marco]-,
Neither of us can prove the other to be right or wrong because we do not have equipment to detect the energy we are talking about.
How can you even make such a statement?
You do not know what i can and cannot prove.
I can and i will prove you wrong.
Marco.
turbo
Quote from: Grumpy on October 08, 2008, 06:12:05 PM
@Marco
Bitchin' avatar Bro!   8)
Is that compass spinning because of a rotating charge field or a rotating magnetic field?  ???
Grumpy, :)
You know rotating magnetic fields do not exist.
It is rotating because the coils switch on and off in sequence and this in turn create the apperance of a rotating field.
Here is the video http://www.overunity.com/index.php?action=tpmod;dl=get148
Marco.
