Lets please use common sense.
Started by nightlife, October 06, 2008, 10:02:21 PM
wizkycho
@nightlife
you wrote
Think about what you said here and remember that friction is always a factor, even at the start and it grows as the power created grows and they are just as equal at the start as they are at the end unless a resistance is added by way of the design and or physical input. Once a design reaches a steady rpm, it is consuming what is produced and if it didn't, it would continue to speed up until it self destructed.
friction is always a factor (yes), It grows as RPM grows (not as power created grows). at RPM max (this is with no load - use just friction for load) or steady RPM it is consuming what is produced...(this is correct)
and if you put little more outside load RPM will fall down, but It will stop only if LOAD is too big.
think of constant LOAD and constant friction like stronger constant friction. constant load completely acts like friction.
so no selfdestruction and no stoping. device works and can give constant ammount of FE.
OU device is another thing. Practically Means closing the loop - Output of Free energy Device connected to Input of that device. If loop is closed then theoretically energy can be multiplied and multiplied again....to infinity but only if you make a such a device that can take that ammount of E
at input (and without some regulator). if don't Fe device will just disccard that input energy (selfstabilize) or energy will destroy input(depends on consrtruction).  (yes you are right, selfdestroy, yes I tought of it before, sorry, I understand what you mean.)
Let's construct selfstabilizing OU or at least with regulator. is my conclusion. let's not make black hole.
Mainstream science as it seems will do that for us...
overaccelerating particles at CERN.  >:(
Wiz
