Thanks to ALL for your help!!
Tesla's Magnifying Transmitter (amplify electricity)
Started by sirmikey1, October 07, 2008, 10:32:59 PM
Magluvin
Hey Tito
How about just giving these guys some general info, things around the device itself. Like how much power your producing, does it take up much space, does it make a lot of noise. At least you would be feeding their search interest. =]
Mags
nightlife
Quote from: Magluvin on January 22, 2010, 09:04:13 AM
That was a cool link Nightlife
But Tesla always claimed high freq. And Yes low freq can be dangerous.
I would say a wide open receiver should find something. Or just fine tuning all the way through the bands. lol
Mags
What if he was attracting a low frequency and then coverting it to a high  frequncy?
What if he used a low frequency's to resonate a coil which created a high frequency after being affected.
Think about hard hitting bass like in hip hop music in a car. Think about how much it vibrates that car and all the ones around it including the buildngs and even the ground. Now think of the sound of the vibrations  created by the bass thru all the different things being vibrated. The hit last for a fraction of a secound but the vibratons last for several depending on the matterial that is affectd by the vibration. If we could attach hundreds or thousands of magnets that are floating in coils on everything that vibrated, think of all the energy that would be created. Then think of how much energy was used. A 4000 watt system will produce a very vibrant hit. The hit will vibrate those magnets creating energy as long as the vibration lasted. Now think of all energy created and I would bet that it is much more then the energy used to create the hit. That is because of the self resonating affect vibrations have on matter. Now isolate the hit and direct it to a coil and  the coil will vibrate as well as create a magnetic field. We then have a vibrating magnetic field that produces energy thru the coil as long as it is vibrating.
The s/m tpu was said to have vibrated. Could it be that he used a pulsed low frequency to create and carry the vibration? Could the vibration have created the electricty it put out?   :o  I think it could because electriicty is vibrations.
Magluvin
You might be right there Nightlife
Now we just need to tune in to about 8 hz and start thumpin. Im into custom car audio and I know what you are saying.
Mags
Tito L. Oracion
Quote from: Magluvin on January 22, 2010, 09:23:13 PM
Hey Tito
Mags
hi mags
ok, currently i only have 1000 watts inverter because that is all i can afford now, my source is an antenna, i'm using #### stage amplification, using a lot of transformer that are readily available in the market cause i'm too lazy to wind ok, the many the transformer the higher inverter watts you have is the power you can produce its unlimited ok.  a half meter by a half meter is enough for the space for a thousand watts.
i think this is my last post. i am not anymore interested in this forum ok
i'll just be watching from now on ok.
ps: no noise ok i've solved that by putting it inside of an aquarium funny but effective, i think oil is much better  ;D
did you see an aquarium based on oil. lol hahahahahaha  ;D  ;D  ;D  ;D
nightlife
  So if  we were to charge a cap and dump it at 8 hz in to a coil, the coil should be able to create enough energy to fill another cap to dump back in. switch them back and forth and you have a pulsed low frequncy input creating a high frequency output.
I am not sure if I am makiing any sense right now. I am thinking outside of th box and I will have to do some research to see if I can be right.
