Tesla's Magnifying Transmitter (amplify electricity)
Started by sirmikey1, October 07, 2008, 10:32:59 PM
delboy
Quote from: forest on March 01, 2010, 03:47:17 AM
Oh,delboy. This is not so simple. Tesla was hiding a lot of information (or those were wiped from his text) - the only tip we can find is in 1900 article about increasing human energy.What Tesla described above is wireless transmission which is never OU.The piston on receiver cause a friction to be propagated back and affect piston-transmitter in the same way as Lenz law affect transformer.
P.S. I mean OU is not in such wireless transmission.It could be "generated" in transmitter alone or "receiver" alone or in DC wireless :-)
There is nothing hidden. Find Colorado spring notes and find patents, and that is it!
Why could not be OU if we generated several MW reactive power with input of several kW ???
Than you put Tesla receiver that will pick up just few percents of that but enough to became OU device!
forest
There is no point to argue delboy. I see you have a better knowledge then me about electronics.
I only said that DC is easier to produce radiant effect. How do you convert reactive power in your Tesla coil with high Q and resonant secondary ? How do you pick up JUST few percents of it without disturbing resonance ? I don't say it's impossible but I just don't know how.
delboy
Quote from: forest on March 01, 2010, 04:27:55 AM
Hmmm, isn't resonance effect that gives rise to reactive power???
How big Q factor than proportinaly that big will be reactive power!
For example, if we have on primary say 3kV and primary is 1 turn and is in loose connection with secondary and primary see only  few turns of secondary, for example 5 of them, and secondary have 50, giving 45 is left! Because nothing is ideal, let supose that we transfered let say 2kV to 5 turns of secondary.
That 2kV is now one NEW SOURCE of high frequency! And we have stil 45 turns left and also there is TOP-LOAD capacity! This is new RLC open circuit: SOURCE â€" 45 turns= INDUCTIVITY â€" TOP_LOAD capacity. This is important to understand. Resonance is possible in an open RLC circuit! One wire transfer!
Than if Q of secondary is for example Q=500, than under resonance this will give 500*2kV =1MV voltage of high frequency. Than you can calculate by uper formula, how big power will be., because it depends on capacity, frequency and square of voltage! Tesla build TC with relativly big diameter. You now why? Because he wanted to reduce loosses in secondary because if you have thousand of turns your voltage will be eaten up by parasitic capacity!
That's why he had only 30-50 turns in secondary but diameter was 3-15 meters which gives high induction necessary to have high Q! Tesla enlarged induction by making diameter bigger not turns! It is also square dependent!
How to collect this power without disturbing resonace?  With one wire transfer (wireless)! One wire can be Earth, Air(over 5 miles high), Sea, Copper etc I must go through something. That's why I call it ONE WIRE. You first must understand pricips of one wire transfer, than talk about how Tesla drive car on some black box bla bla. You are skiping the important part in Tesla's life.
You have patents 645576 and 649621 describing transversal receiver. Receiver is reverse of TC. Or if you want logitudinal one than look at 685955.
Ask your selves, how come that bulbs are light on connection C when they are short circuit?
I recommend reading this :
http://www.tfcbooks.com/tesla/1919-05-00.htm
http://www.tfcbooks.com/tesla/nt_on_ac.htm
Magluvin
hey delboy
Be cool. =] We appreciate what you have given here. It has opened my eyes to something that I just wasnt able to see before on this.
I think this will be good for all as they gander and see.
I am envisioning the possibilities of pocket size versions. having many individual devices , 1 for every product or use.
No more wires in the walls. 1 for the electric car that really does not need to put out much more than the recommended charger necessary  to charge the batteries. or all the way to eliminating the batteries.
But this pat lended to the realization of how it could be done easily as compared to what we have been trying to figure out for months. Well now, for me, most of the pieces are here at hand. You can go to radio shack and get all you need to do it. Im going to experiment with a bit at a time to get those first things going and see what we see. Then continue on. Once we get the base going, waiting to figure out the last part, we will be prepared to add that as we sort out what gives us what we want on the output.
I would like to see some projects going on in this or my new thread, which ever, its the same. =]
It will be fun.  ;]
Mags
Magluvin
Bang bang!  "1 wire transfer"  I just asked tito about that.
i like what im hearing
mags
