Thanks to ALL for your help!!
Awesome Discovery or Simply disinformation?
Started by Magnethos, October 11, 2008, 06:39:13 PM
Magnethos
Quote from: 4Tesla on October 12, 2008, 01:33:19 AM
I believe this is as simple as you are just creating a common ground, which probably increases the voltage..  that is my guess.
It isn't a good idea to hook up two different voltages in parallel.  There isn't any free energy that you can get from this.
This site may help: http://www.batteryuniversity.com/partone-24.htm
Also look up "common ground" and "floating ground"
Jason
Thanks for the link, I'm starting reading it now.
But my question is..
Why the effect I have seen only happens when the red wire from the 24V@0.29A is disconnected?
If I connect the red wire to the fan together with the red wire of the 9.5V@0.55A the effect DOESN'T happens
When I connect 2 Red Wires + 2 Black Wires, the fan DOESN'T increases the speed. The fan only increases the speed when I connect 1 Red Wire + 2 Black Wires. I think if the second red wire is not connected, is impossible (IN THEORY) to get energy from the second wall transformer, so IN THEORY only the first wall transformer is drawing energy to the fan. So, Why the fan increases the speed when I disconnect the second red wire? If I connect the second red wire the effect doesn't happens.
Can you explain me why?
Magnethos
Correction, sorry:
If I connect the red wire of the 24V@0.29A to the fan together with the red wire of the 9.5V@0.55A the effect DOESN'T happens
Magnethos
Magnethos
@4Tesla
I'm reading little by little your link and I'm learning, thanks. But...
Look at the pictures:
All the experiment that you can see are made using a dipole connection for each one battery. In my experiment I have a dipole connection + monopole connection. Of course, your link has been very usefull for better understand batteries, but it doesn't answers my question (all experiment use a dipole connection).
@All
Strange batteries, are not a monopole connection. Strange batteries in the pictures means DAMAGED batteries.
pese
Quote from: Magnethos on October 11, 2008, 07:11:36 PM
The fan: 12 VDC @ 0.33A
And the B transformer is 9.5 Volts 0.55 A, instead 9V @ 0.33A sorry
The output voltages (from Supply Plugs)
is it  DC  (VDC)
or AC (VAC)
this must be very different in the application....
but in both way , very suspect
GP
