Hydrogen Generator with heavy duty CPVC Mason Jar lids
Started by bandr60, October 24, 2008, 04:01:06 PM
What do you think of this design?
your thoughts
2 (40%)
do you like what you see?
3 (60%)
Total Members Voted: 5
Rocko
Yep, these babies do xplode
Did it several times testing safety features and found that something like a popoff  cap or tube will release the pressure fast enough to leave the (PVC) cell undamaged (never tested glass). Even tho i know my containers wont blowup i still cringe at the thought of an xplosion because it is LOUD.
I did see a video that claimed of an implosion but it was in an engine and didnt happen consistently, totaly different situation than a cell.
The lids look sweet but the glass would worry me a bit  (just my opinion), i guess if nothing will cause a spark in the container under rough conditions it should be ok .
jeanna
Rocko,
It seems to me that you are using the word explode to mean a cold explosion caused by the build up of too much pressure in the first generator.
@All,
I saw the youtube vid too I think. I saw one where a bunch of guys who had made the generator cell from a hard plastic water container. The first moments the guys were laughing excitedly because of HOW MUCH gas their device was producing. Then kaboom. The whole thing exploded. There was no flash no heat just water everywhere. Someone had the presence of mind to turn off the power immediately. They laughed and "F-ed" a lot and then the vid was over. They kept saying how wet they were water everywhere.
This may be wet but it is not a flaming explosion. These are 2 very different kinds of explosions.
People must be clear about this. I cannot tell you how many people have warned me to be careful with my HHO generator and to take all the precautions etc.
Of course, I will.
I will post these 2 links. There are more, but these are very informative.
first from Yull Brown himself:
Quotehttp://www.nottaughtinschools.com/Yull-Brown/Free-Energy-Lecture.html
This site has pages of videos as well as written information.
from
Quotehttp://fu.fi/~esa/merlib/?q=node/5676
Enjoy!
And, I hope this clears up some fears I see being expressed.
jeanna
woodpecker
My too, i started my journey in to the hydrogenland with designs, quite similar to this one and in a way i am thankful to the people working with it. But my own experience was, that it was so difficult to get a good sealed cell, good sealed connections to the tubing and i never could get out that amount of gas, as promised. I have lost quite a lot of time and money with that ind of design and finally i got strait into the building of compact drycells. With these i had perfect sealing, perfect sealed connections and a fantastic output of gas with low Amps. and the drycell will always survive any flashback without hurting anybody. From my experience i can only say, that it is much easier and quicker to build a drycell, then a Open bath Electrolyzer and the drycell will always beat any openbath electrolyzer. Maybe as a booster for  cars, efficiency is not that much the problem and maybe it is still a good way to give people a basic understanding about these things, so don`t feel this as critics.I just wanted to share my own experiences with you. And i hope, that done day soon, you too will start to build drycells.
http://www.youtube.com/watch?v=5DJDKYXmIWM
woodpecker
Rocko
@ jeanna
NO
I mean xplode , as a flame put to the gas to test safety features and an explosion as a direct result of the flame.
absolutly without a doubt there was an explosion as a result of the flame and there was not anywhere near enough pressure to cause what you talk about.
I saw the video you speak of and that was caused by pressure. There may be a slight implosion before or even after the EXPLOSION but there is to cause a a plastic pvc cap to fly across the yard. Zerofossilfuel has some video on UTUBE that show what im talking about.
My knowledge is first hand, HHO can be safer than gasoline and if not respected it can be much more dangerous that gasoline so regardless of what anyone claims I know to respect the power of HHO
good luck
bandr60
I have been experimenting with HHO production for several years now and have used multiple style containers.
As far as mason jars these are far better than pvc containers because they will not distort when heated up, the lids that typically come with the mason jar designs that I have seen have always been a problem. Especially if you are going to use plates.
The carriage bolt designs tend to work well with the lighter plastic lids.
If someone was really worried about the jar exploding all you need to do is install these in a plastic container as an extra precautionary measure.
I do suggest that anybody using hho cells use a bubbler and a PWM (pulse width modulator) as these help control the amperage and keeps your cell from overheating. www.extremehho.com has an excellent PWM that is enclosed with a cooling fan and front facing amp meter and controls.
I have seen multiple designs for HHO Generators but dollar for dollar the generators I sell here at www.hydro-extra.webs.com is a great solution to minimum maintenance and high output with my 316L stainless steel plate design and heavy duty CPVC mason jar lids all kits come with the bubbler, flashback arrestor, 10 gauge  wiring with fuse block w/fuse and terminal connectors, braided hoses, air intake plenum elbow w/nut and a tee for vacuuum connection, check valve, custom machined heavy duty o2 sensor extender as well as complete installation instructions .
I can custom arrange your plates however you would like. If you do purchase a PWM you do not need the neutral plates and can increase your production even more, my generators come stock with neutral plates to help control amperage, but as all cells a PWM is highly reccomended.
