Hydrogen Generator with heavy duty CPVC Mason Jar lids
Started by bandr60, October 24, 2008, 04:01:06 PM
What do you think of this design?
your thoughts
2 (40%)
do you like what you see?
3 (60%)
Total Members Voted: 5
jdcmusicman
Yeah no one should be going in blind with this hho . Yeah as long people are safe things will be safe , but can have an occasional accident with hho even with being over safe ..And as far as plastic ,pvc, and acrylic ,yeah it can blow into pieces to but I think I would rather have a piece of flying plastic hit me instead a piece of glass....Just trying to help thats all...
jeanna
Just to clarify for all the folks who are afraid the HHO will explode and hurt them...
HHO is unique because it IMPLODES, This means if there is a flash back, it will be sucking air into the mason jar NOT blasting fire out of it.
Now, when the HHO is added to air in your air intake and it goes into your engine, it changes its characteristics to explode. But now it is in your engine where an explosion is designed in.
So in the original mason jar as well as in the bubbler and the tube,,, everything until real O2 gets mixed with it, it is an implosion and so if it breaks the jar it will stay all in one place.
I am interested in using one of these as a welder, and I have been checking this out. You can light the end of the tube that comes from the bubbler, and use this gas for welding.
Only when you want to cut something do you add O2.
Once you do that wow it is really hot.... but as I said, THAT is what is happening inside your ICU.
So, please relax.
Personally I think it looks great.
My question is how many amps does it draw? If it is on the website, I missed. Please describe. Are you using electrolyte when you quote the output? etc?
jeanna
bandr60
Hi Jeanna,
These do not draw any amps. until you add an electrolite, you can use any type of electrolite whether it be vinegar, baking soda, sodium carbonate, sodium hydroxide etc.
The output readings that I recorded were with baking soda and sodium hydroxide at 22 amps.
The advantage to sodium hydroxide is that the cell runs cleaner, last longer, and only requires 1/16 to 1/8 teaspoon of sodium hydroxide.
These generators tend to run much more efficient when ran in series, they run cooler and use less distilled water.
I am currently running two in series with a PWM and I can control the amps for city and highway driving. It is best not to run more than 10 amps at idle because more than 10 amps at idle is to hard on the alternator.
Once you get on the highway you can adjust your pwm to your desired amperage which tends to differ from ones perspective to another.
jdcmusicman
A hho generator makes hydrogen on the negative side and oxygen on the positive side.
I have been conducting experiments with this stuff for over 5 months and ..HHO is hydrogen+oxygen ,
Light a match to some in a jar , you will find out real quick like that it EXPLODES ...Of course if you do test with this stuff , after the explosion takes place , it then implodes a little..I done it tested it ..this is what it does ....To think that you are in no danger until the gas hit the air , is misinformation...
thats why its called HHO   2 parts hydrogen , 1part oxygen ...Trust me it explodes ....with out having any outside air contact...
topothemtn
  jeanna.
  Sorry to dispute you,but when you get a flashback into a hydrogen generator you get a very LOUD explosion. No flame to speak of.   I had cells made of 2in. PVC with press on caps ( for safety )  when I was trying to light up a torch without a safety bubbler ( I'll never do that again )  I got a flashback , it took out the flourescent light above and dented the light fixture. I was three feet away and wasn't hurt (except my ears).
Have you ever had one explode or implode?
