Pulse Generator
Started by slayer007, October 31, 2008, 07:42:52 AM
slayer007
Here is a good video lidmotor made.
http://ca.youtube.com/watch?v=zCE-C-_S_WY
If you totally disconnect the cfl but still use the ignition coil the way it is you'll get a LOT more power.
Nothing in the ignition coil just use it for power.
b0rg13
Quote from: slayer007 on October 31, 2008, 09:05:15 PM
very nice.
if you want to get out of the rat race,you have to let go of the cheese.
slayer007
Quote from: Groundloop on October 31, 2008, 06:43:36 PM
@slayer007,
Sorry about the transistor marking, it was a "typo" error. :-)
(Moderator: Can you please change the modify time to more than one hour?)
Thanks for the feedback. I do not have an car ignition coil here so I can't try a replica.
Your idea of sending the back emf voltage pulse through a coil is smart. I have tried
something similar some time back. I used the same method. I used a transformer
instead of a single coil. The back emf voltage can then be put to work instead of
beeing wasted. Good idea.
You could try any coil it dosent have to be an ingition coil,but they do work good.
And you dont have to wind another coil.
slayer007
Here is another circuit this way you can still light a 110v night light and still keep 40v in a capasitor.
And it only uses 10 Mill amps or lower.Some times my digital meter went to Zero.
Its only good to 10 mill amps.
Groundloop
@slayer007,
I see you have removed the ignition coil in your newest circuit.
Also two diodes in series is loss so I used only one in this drawing.
You have made this oscillator under unity by only using the back emf voltage.
If you want to make an over unity oscillator then you must find a way of switching
a huge flux with just a little flux. The attached circuit is a attemt to do just that.
The Neo magnet makes a huge flux in the leftmost core. When a small flux is present
at BOTH cores center then the huge flux is coupled to the right core.
What do you think of this idea?
Groundloop.
