Pulse Generator
Started by slayer007, October 31, 2008, 07:42:52 AM
b0rg13
if you want to get out of the rat race,you have to let go of the cheese.
slayer007
Quote from: b0rg13 on October 31, 2008, 03:51:55 PM
http://ca.youtube.com/watch?v=_TR6eRYr4Rg
http://ca.youtube.com/watch?v=FwuWFIj5xnc
Thats my old circuit b0rg13.
the new one you get allmost twice the power out of it and it only uses half as much power to run. ;)
Groundloop
@slayer007,
Attached is cleaned up version of your circuit. I have two questions,
1. Is my cleaned up drawing correct?
2. What input (Voltage*Ampere) and output (Voltage*Ampere) measurements do you have for this circuit?
Regards,
Groundloop.
slayer007
Quote from: Groundloop on October 31, 2008, 05:16:04 PM
@slayer007,
Regards,
Groundloop.
That looks great Groundloop thanks.
But the transistor is 2n3055 other than that it loos GREAT.
!2v in from a 12v battery,The output after 110v nightlight was put on for a load was 130v  to 150v Left in the capasitor.
I tried a a big dc motor to check the amp output it was 80 mill amps in even when I tried to stop the motor it stayed around 80 mill amps.
The output was around 60 Mill amps but then when I tried to stop it it went up to 80 mill amps so it was allmost the same.
You have to try this one ;)
Groundloop
@slayer007,
Sorry about the transistor marking, it was a "typo" error. :-)
(Moderator: Can you please change the modify time to more than one hour?)
Thanks for the feedback. I do not have an car ignition coil here so I can't try a replica.
Your idea of sending the back emf voltage pulse through a coil is smart. I have tried
something similar some time back. I used the same method. I used a transformer
instead of a single coil. The back emf voltage can then be put to work instead of
beeing wasted. Good idea.
Groundloop.
