Pulse Generator
Started by slayer007, October 31, 2008, 07:42:52 AM
slayer007
Hello jas_bir77
This is the latest circuit I have been working on.
This one you take your BEMF comming from your collector thru a diode then back thru your second coil winding.
Some how it amplifies the voltage.
In my diagram I'm showing I have the charge battery negative going back to the source battery negative.
But you can allso run it to the positive of your source battery allso.
@Goat
Thank you
slayer007
@ All
Sorry about the drawing I dont know why it came out so big. ::)
nievesoliveras
@slayer007
I took the photo and centered it with paint and resized it with irfanview and here it is:
Dimensions now are 620 x 558 x 24 bpp
Jesus
slayer007
Quote from: nievesoliveras on December 13, 2008, 05:39:20 PM
@slayer007
Jesus
@Nievesoliveras
Thank you.
jas_bir77
Quote from: slayer007 on December 13, 2008, 04:23:18 PM
Hello jas_bir77
@Goat
Thank you
:-* :-* ;)y i tried your new circuit and its working .grate ;D ;D.  but i am facing a new problem i.e. my reed switch which i have kept parallel to my coil after 3- 5 min it stops vibrating (i have also soldered another reed switch perpendicular to my 1 st one as you had said earlier size of my reed switch is 20 mm by 4 mm) after it stops i wait for 5-7 min nothing happens  ,so i take away my magnets and i again bring back the magnets to the same position where i had placed earlier , now again my reed switches starts to vibrate and keeps on vibrating for another5 min or so. ???
Another  thing i wanted to ask was that to increase the charging rate can i place an ignition coil in your new circuit from the collector in your circuit i had mentioned in my earlier post or should i add the ignition coil from the collector in your 2 transistor design . ???
also i wanted to know what all i can do to extra to increase my charging rate(i should increase my winding on my bifilar or i should increase the no of wires or the gauge of wire ). ??? ???
