Bedini SSG puts out 800 volts using auxilary inductors!
Started by supermuble, November 02, 2008, 08:43:07 PM
supermuble
Tonight I had 1500 volt spikes by adding another inductor in series. As if by magic, my meter registered 130 volts DC (NOT AC)!!
How in the world did I manage to create 130 volts continuous (1500 volt spikes) by merely adding a single extra inductor? See attached pics!
Now if I could just learn a little more so I can apply some of these concepts better.
I have not had enough running time to confirm that my setup can make a repeat performance like it did when I first saw the drastic charging effects. To hook it up, you hook up the NEG from the primary battery and the NEG from the charge battery to one side of the inductor. The negative terminal from 1st and 2nd batteries go on the same side of the coil. Now you should have an extra ground wire coming from your SG circuit that is not attached to anything, hook this up to the opposite side of the coil, to the opposite wire from the NEG of the primary battery. Now you have one wire left on the bifilar coil, this goes to the positive terminal on the main running battery.
You are linking the two batteries together through the inductor, and then you are linking the ground wire from the primary battery to the SG circuit through the same inductor on the same core. The funny thing is, this is the same concept Stan Meyer used for his VIC (voltage intensifier circuit) to make hydrogen from water. He used a variation of a simple bifilar coil. When power went into it, it would stop the flow of amperage by the bifilar coil having a canceling effect. The power would build up in the water capacitor because it couldn't come back into the magnetized inductor coil and then the water molecules would break down from electrical stress. This seems to be something similar to the situation I've created with my Bedini batteries.
Whether it is the type we want for charging, that is yet to be fully determined.
It should look like the picture above.
BTW, Don't get shocked. :o 1500 volts turns out to be somewhat painful  :D
I'll work on a schematic tomorrow :)
identity
hi supermuble, nice discovery of the new mods for the ssg. could you please post an schematic of the mods you made, so we can replicate it accurately and easily. Thanks in advance. :)
innovation_station
nice set up ..
i can not see your pics at present tho but it dont matter i know how it works and
i offer this for advice use heavy gage coil  i have too seen 1900vac spikes from a pluse from a 9v  or 12v  awell i have been zaped big time  ;D
it knocked both my arms numb  for over 10 min .....    ;D
i also fired my tpu for the first time only 1 coil it has a cap in it same curcuit tho...  it fired me 477 vdc i have 6 of thease indivigual units in my tpu   my caps are 500vac 13uf  oh yes the fill quick.... lol
ist
keep up the great work...
nievesoliveras
Hi!
Is this what you meant by your explanation?
I put the bifilar coil between the two batteries.
Jesus
nievesoliveras
Hi!
In order to make a good replicatiom of yours, we need to clarify the coil connections first, then how they interconnect with the SG circuit.
Is this the correct connection of the coil?
Jesus
