So is it rocket fuel?
Started by c-cat, November 04, 2008, 10:39:04 PM
c-cat
The turbine type is naturalgas (vapor). I'm running numbers on an old turbocharger (cfm's and such) to use as a pre-metered hydrogen/nat.gas pump,or blender if you like. It will be driven of a pressure tap on the compressor (cool end) although it still gets hot.
Magnets are fun until they stick in you.(I was 12)
Lasers unfocused or not can burn.       (13)
Won't microwave laser beam again      (14)
Liquid hydrogen and gas turbines don't mix well (15/16ish)
Have .5Mw generator to play with (current) hyd. gas fueled.
the_big_m_in_ok
c-cat said:
In my somewhat strange or obscure thought process, Ive seemed to imagine that thru electrolosis hydrogen and oxygen are formed. Further clunking of my noggin lets me believe that if electric power generated around the compressor stage of a low speed turbine (@ 40k rpm) it might be enogh power to create (rocket fuel) to warm up the loud end.
>>My dad was an aerospace engineer, so this subject is one I'm familiar with.
Electrical power and heat are interchangable in dimensional algebraic formula, so I believe(?) unless you use something like a free energy setup similat to a Mobius/Caduceus/bucking/etc. coil arrangement to overcome resistance losses in wires for example, your proposed system may not be as overunity as you might wish.
--Lee
