Batteries charging under pyramid : replications
Started by Tigrotto, November 12, 2008, 12:13:20 PM
Tigrotto
Hi to all,
I want here to open a trade ( I hope interested for some of you) by means of which I want to contact persons who did the same experiments like mine: accumulator charging using pyramids.
Two words at the beginging of this thread:
1.I did some experiments managing to charge batteries under pyramid.
2.I repeated these experiments successfully.
3.I tried to improve the quality of the effect and I'm working right now on this.
My puropose is to cooperate only with experimentators doing the same work like I did.
Thanks to all of you ,
Tigrotto
traderfx05@yahoo.com.au
pece70
Hi Tigrotto,
   still you working on this project?
Cesare
spacetrax
Hi,
I never tried to charge accumulators under pyramid. Are you talking about lead acid accumulators? I have 6 volt and 12 volt accumulators lying around and I still have the 1 meter pyramid made after the instructions of Thomas Trawoeger.
So, what I can do to replicate your results?
Quote from: Tigrotto on November 12, 2008, 12:13:20 PM
Hi to all,
Tigrotto
pece70
If it could be useful, I tried to charge lead acid 12 Volt batteries.
I put them at 1/3 h of the pyramid, nord oriented, with positive pole of the battery in the same direction.
The battery recharged itself at 2/3 of the maximum. It took one or two days.
I haven't done any "perfect" measurement. This was an experimental evidence that "Something" is real by itself.
Standing from this evidence I were intersted in amplification of the result.
I'm building up a very perfect pyramidal shape, made of copper filled tube (2,5 cm), base: 21cm x h:21cm.
My tests restart from here.
I'm interested in radionic resarch too.
At the present time I know from radionc that electricity passing on a wire emits (other than EM field, of course) some other radiations, one fo them is called "negative green" (that is a form based radiation, named by DeBelizal and Chaumery).
Furthemore, I know that at the 1/3 h of the pyramid there is this the negative green radiation (very dangerous for human beings, be aware!), in the form of a sphere.
So, right now, I wondering if there exis some way to convert one in to another and viceversa.
amigo
pece70,
I'm wondering, how do you know the battery did not recharge itself without the influence of the pyramid?
You know that batteries recover some charge over time so perhaps a better experiment would be to get two batteries, drain them simultaneously and then put one under a pyramid and keep the other on the shelf as a control sample.
But, aside from batteries, I am interested in the geometry and radionics and will be conducting experiments in the future. I am looking into works of Les Brown with crystals and pyramids, as well.
