Lynnferd Grant HHO Breakthrough
Started by goldenequity, November 14, 2008, 09:33:48 AM
HeairBear
Quote from: epeirce on November 24, 2008, 08:03:40 PM
@HeairBear
water for fuel.com has a pretty cool wave coming off of his alternator.
HOLY SHIT! Look at those prices! I love the idea of using a PWM for the input to the alternator but there is a way to do that and still keep the ability to adjust the voltage(0-140V). With just a PWM you are restricted to the 12V it's designed to run with. I like his work, I hate his prices...
When I hear of Shoedinger's Cat, I reach for my gun. - Stephen Hawking
sucahyo
Thanks for the info HeairBear, I thought meyer want to replicate tesla by doing ramp up voltage where the diode rectify the impulse to make it unidirectional, the really high resistant coil will act as electron stopper which allow only ether to pass trough, water act as capacitor, and the water break down process as spark jump. He would need high voltage square wave for it.
But there is flaw in this assumption, I don't think transformer specified in the patent will produce square wave output even if the input is perfect square wave. Besides, I don't think harmless ether (high freq type) would electrolize (harming) water.
I hope there are more finding in Meyer cell replication. It would be a great loss if we can't replicate it.
Agree that those electronics priced too high, it is enough to buy a complete HHO generator
Kator01
Hey Luc,
another unnoticed fact I became aware of  (it often takes some time until the penny drops ) :
Ultrasonic is used for cleaning the surface of a metal or material that is able to edure the vibration without getting broken.
Now in this experiment - when ultrasonic has been switched to stage 2 - then dirt is coming off the plates - contaminates the water -> lowering the resistance and here we go ... normal electrolysis starts at this voltage-level. Ultrasonics just paves the way ...
This will even happen with steam-destilled water   . amd dirty plates ( or spoons )
Have we bee shown in this video the bubbles rising up in between the plates ( spoons ) ??
I will do tests anyway - but only with very clean electrodes - you bet - and will not expect any new phaenomenon here.
Kator01
sucahyo
I have watch some ultrasonic video and here is what I learn:
- ultrasonic tranducer  clear up the bubble mist and make the device produce larger bubble
- ultrasonic tranducer reduce efficiency
All of the above characteristic seems the same as the difference of current density. Ultrasonic tranducer  made electrode behave like it receive higher current density. Higher current density have larger bubble and less efficiency.
This should explain why turning on ultrasonic tranducer make the bubble come out. When there is no bubble form/ very slowly produced, when ultrasonic tranducer turned on, the electrode surface will act as like it receive higher current density and make the surface release bubble more. But when the electrode surface already release bubble, having ultrasonic will increase the size and make it less efficient.
I think we should also try to find the way to reverse the ultrasonic tranducer effect.
article "EARTH POWER SPECTRUM AND ITS POTENTIAL AS A USABLE ENERGY SOURCE" have interesting note:
QuoteThe Earth’s atmosphere vibrations are harmonically related, and therefore desirous of self-oscillation, as given by Keely. In the article referred to about the Hendershot device, the frequency of 14.3 KHz.,if multiplied by 3, equals the frequency of 42.9 KHz., if multiplied by 6 equals 86 KHz., and by 9 equals 128 KHz., another observed frequency, or when multiplied by 12, equals
almost the suggested frequency of Hans Coler. These inventors were clearly on the path to utilization of this abundant energy source, which surrounds us each minute.
sucahyo
Yesterday I want to try to "poisoning" the DC input of my cell with my soundcard sine/square wave output. I use a toroid with same turn for both primary and secondary. I pass the cell input trough secondary (white wire), and intent to pass the sound card output to primary (blue wire). But I have problem with my power supply. Everytime I connect the primary to my sound card output, the power supply died (my monitor flicker for a moment too). It would take some minute of disconnecting power for the power supply before it can be turned on again (which usually takes seconds).
Anyone know why this happen, and more importantly, how to prevent it from happening?
Ohmmeter set at 2M do not detect any connection between primary and secondary. The video show that when I stick one end blue wire, the other end free, to my computer case, it will spark and halting cell power supply.
