Joule Thief
xee2
Successful test with k1zm-slayer007 toroid circuit.
xee2
Circuit will light two tubes in series, thus is putting out at least 1000 volts. Neon shows output is AC. Frequency is about 25 kHz.
sirmikey1
@all
   I had a question for you guys, but hard to put into words (green).  I am basically pondering all of the recent JT filament bulb circuits; and Marko's Filament Bulb Start+Run Cap Method in this video below has me thinking that his method (NO CAP CHARGING+SWITCHING NEONS/TRIAC/SIDAC) can be applied to all of these other BEEFY RESONANT curcuits:
http://www.youtube.com/watch?v=2ODW-ntPHSU
  My thoughts are that putting bank of caps on L1 & L2 ( or L2+L3? ) would accomplish same results, capacity.  Any ideas or comments?
Mikey
altrez
@all
Ok I am on to something odd perhaps some of you big brain folks might be kind enough to explain this to me. Tonight in my home lab i was working on a simple SEC that was posted back 20 pages. It was using a trigger coil. I could not get it to work no matter how I ran the circuit. So I got upset and moved on to my JT test bench.
This is when things got odd. I know all about energy coupling and i think this is what is going on here but the odd issue is that if I hit a certain frequency power drops for a split second and BAM magic well magic to me at least. My theory is that I can run many cores and have then all generate power from but one source. And as I add them the amp draw gets lower and lower.
a few pics..
The LAMP is an LED light and its running from the JT.
xee2
Quote from: altrez on March 10, 2010, 08:38:33 PM
I think you need to explain a bit more. Magic what?
