Joule Thief
0 Members and 85 Guests are viewing this topic.
forest
RUN FORREST RUN ! LEAVE ELECTRONS BEHIND, YOU WILL CATCH  NEW ELECTRONS AT THE END !!!  ;D ;D ;D
forest
SHIT HAPPENS,POWER HAPPENS.DO NOT BUY SHIT!
ouch ,Im going nuts....psss hiss catch catch..
IST! free ELECTRONS CATCHER !
innovation_station
here is my newest unit
it is the entire system on 1 board ..
add a coil and battery holder your done ..
i have 2 caps 25vdc 4700 uf  1 per coil then joined as 1 feed
need a coil ?
ist!
woopy
Hi Slayer
Back to work
I read some Dr Stiffler threads and came to some ideas
First    i did a pancake coil (pix 1)  as you suggested    8 turns  0.5 mm copper    and 0.35 ohms resistance     and 2,5 micro h  inductance
it works very well
second i tried to use water as transmitter  and it works well  it is simple tap water without any electrolite     To test it i used my diode bridged led with antenna and took the distance where it lit off,  than i put the water container under this distance and plunged the antenna in the water and the led lit up very brightly. (not very clear on the photo but real in my lab)
very interesting anyhow
good luck
regards
Laurent
slayer007
Quote from: woopy on March 24, 2010, 06:40:18 PM
Hi A
Back to work
it works very well
good luck
regards
Laurent
Very nice job Woopy.
For your pancake coil you might get even better results with plastic coated solid wire.
For me anyway the plastic coated wire worked a lot better than the mag wire.
Great job and thanks for posting your results.
