Joule Thief
Quote from: synchro1 on August 15, 2021, 06:24:16 PM
How much power would a 12 sided dodecahedron collector box of high performance photovoltaic cells generate over an extended run time with the 220 volt LED bulb fully illuminated inside?
A measurement of intensity in Lumans would permit the summation of theoretical power consumption. The comparison would deliver the  actual overunity COP.
12 sided dodecahedron collector box :   size ? solar cell/modul/panel
high performance photovoltaic cells  :     % efficiency related radiation nm wavelength
220 volt LED bulb                           :   red,blue,white,green ?
Jerry Vollands 5x are similar the spanish inventor Baquero Menendez his PV light chamber with 8x 1,8mtr. 240 W panels and 500 sodium lamp as light source
lumen/Watt difference between CFL and LEDs are in the CFL 1 /LED 2 range ,the CFL consume can be reduced with controler :
https://worldwide.espacenet.com/publicationDetails/description?CC=US&NR=5130608A&KC=A&FT=D&ND=3&date=19920714&DB=EPODOC&locale=en_EP
The module can be understood to be similarly used in combination with a plurality of parallel incandescent lamps or luminaires. Furthermore, the present invention is suitable for use in a lighting system combined either with a filamentous (e.g. tungsten or tungsten-halogen) lamp or a nonfilamentous lamp such as a pressurized gas lamp as used in street lighting systems.
senna2
Quote from: erfandl on July 03, 2021, 02:11:25 PM
LS gadget mod self charge finally replicated and I'm happy :)
Start voltage: 2.613, After a week it is still at 2.613 volts.
Hi erfandl,
May I ask;
1. what is the voltage value of the electrolytic cap (10,000uF)?
2. Also there are two ceramic nonpolar caps valued with .0001uF and 220pF in the schematics. Where would 220pF cap go? What are the voltages of these caps in your circuit?
3. I see a variable resistor right next to the LED.  What is the ohm value of it?
Trying to replicate your circuit. Thanks to you! :)
Pablo P
erfandl
Quote from: senna2 on January 31, 2022, 11:19:43 PM
Hi erfandl,
May I ask;
Pablo P
Hi.
1- it's 35V 10000uF
2- two 100v .0001uF capacitor in parallel
3- 100k variable resistor
forest
erfandl
I wonder if efect would be still there if replace germanium diodes with Schottky ?
Can you give more details , explain how you wound transformer ?
forest
Can you mark on schematic direction of winding coils ? I see there is no 100k resistor on schematic, can you post correct schematic ?
