Joule Thief
0 Members and 169 Guests are viewing this topic.
TheNOP
@Artic_Knight
going green is one of the aspects of the jt.
but have we found how to tune the coils for best effecientcy ?
Artic_Knight
so these toroids have a optimum freq, whats the freq of this curcuit again? somewhere from 10-50 thousand cycles a second? so were looking at .1 to .5 mhz right? thats a grey torried according to the list i found...... can anyone confirm this data?
Mk1
@all
I have to say how funny it is that people think i am angry, Just to show the problem that we are facing is bigger that i tough.
Today people see everything negatively and anything could be said , because of that mind set most get the opposite of what is said.
My goal , is the light the positive side. See things for what they are ! And the modern man can't see anymore, all idea are dictated by other source .Everybody got there field of expertise , and because they got papers they know(reality check, first papers means you learned what they want you to learn, and only strait A's student should be proud of the brain wash.) they are getting the money so they should know.
We are part of nature, all the secrets of the universe can be found in nature, we have no problem understanding( but it is not a book , it goes step by step, you can't get a head unless you got the last step, only then you will be ready for the next.
You make your world, please make it a positive one.
My real goal, is education to me its the only way out of slavery, yes you are all slaves , it is about time to do something.
If i wanted to make money , i would have stay clear of this site , just stealing idea from it for my benefit , that's the old way and it clearly don't work.
Sorry, for those of you how will get the opposite of what i am saying.
Mark
My field of expertise are , music , arts , chess, people, the magnetic universe , and some electronic ! I create stuff not destroy them.
Edit: Ok only 20 mili that is strange i have burned my fuse in my meter with 20 mili?
Also : anyone plays chess?
jeanna
@MK1
I agree with you, mark.
Also, I want to say the EB only comes later when we have some idea of what we have. So far, our experiments have shown unexpected results. There are no equations yet.
I am also here to help dissolve the prison walls. Just seeing them, then later seeing through them will help them to dissolve.
Keep the sight far.
thank you,
@ Arctic Knight,
did you get the jt circuit to work as a little circuit with the light yet? Only after you prove that, should you take the light out and wind the secondary.
Also, remember I got results from ONE turn around the secondary.
Turn a secondary wire once around the toroid of the circuit once you have proved it is set up and working.
The ends of this secondary should light a led. turn the led if not.
Once that gets working, you can light many leds in a parallel way, but if you want to add any in series, you will need to make more turns to achieve that.
If you want to see how many volts are across this secondary you must use a bridge rectifier instead of the leds.
If you do not have a real ammeter, put a 1 ohm resistor in series with the pos end of the battery - right there at the battery, and measure volts, then use ohms law to get how much amp draw there is from this circuit.
AK, I am addressing this to you, but we have found that every once in a while it helps a lot of people to have a little recap.(so I am taking this opportunity to do that.)
I am now wanting to scale this up a little.
@xee,
Thank you for making a word statement out of that formula from hyperphysics.
Thanks everybody,
jeanna
Mk1
@All
The 26 , Monday something big will happen, i don't know what yet.
