Joule Thief
0 Members and 114 Guests are viewing this topic.
Mk1
@all
My fuji , I removed the ballast from the bulb and it works just as good as a 4 foot pole.
Mk1
@all
my transformer thief , 2n3055 transistor.
This one gives me 80 volts from rectified ac, even after rectifier i get a 25 volt ac reading i have charged a cap to over 120 volt (i stopped there for the mythbuster moment yes the discharge sparks looking like welding , it lights a neon rated at 120 volt ac but about only 70 is required .
The blue leads are not used but could rectified again not to send any thing back in the coil only out because it causes counter field in the bigger coil.
Mk1
@all
transformer thief with a neon 120 vac
Mk1
@all
Regular jt running 4 led in series with on the additional windings
When i checked readings on this one with the bridge diode, i got 14 volts per additional coil wire. and could very light some more in the usual joule thief fashion.
Mk1
@all
Joule thief with prime and secondary on each side. Germanium transistor.
And some time to digest .
