Joule Thief
0 Members and 220 Guests are viewing this topic.
electricme
@Xee2
Now this is very interesting, using the magnetic pulse to excite another pulse to trigger the transistor.
Quote from: xee2 on July 30, 2009, 10:23:05 PM
Another untested design. This is simpler and should work better. I do not have an ignition coil to test it with yet. The wire wrapped around the ignition coil acts as the base coil for the JT and the ignition coil primary acts as the collector coil for the JT. The ignition coil secondary acts as the JT pickup coil.
Excellent theory.
jim
nievesoliveras
Quote from: innovation_station on July 30, 2009, 09:05:08 PM
im glad everyone is haveing great secucess
;D
i just drew up my tpu unit ...
... :D   ;) great work jesus and gary you guys are makeing this what it truely is .. we all are ..  :)
ist
Thank you @ist !
It would be great If I understood more of all the Tpus that you have made. But I dont understand much about Tpus.
I know that you will not do it. But it would be great if you add the circuit of the invention that you show on your thousand photos.
We would be richer in knowledge if you had posted circuits explained of how to do the device shown on the photos you have posted.
Anyway, we appreciate you the way you are!!!
Jesus
innovation_station
im not sure i understand you jesus...
it can only work 1 way ...
hummmm
it cant be hard to hook it up
all your doing is a jt ....  the loop is your output wire .. or alum ....  you use a diode to block and protect .. or a bridge
there is a switch a cap 2 coils and a bridge how hard is it ?  just charge the cap and push the button ....
ill draw you a picture ...
lol
ist!
THAT DIODE IS GOOD FOR LIKE 240 000 WATTS.....  ;)  600V 220AMP X 2 HIGH VOLT HIGH FREQ  RECTIFIER ...  PRETTY MUCH A QUATER MEGGA WATT ..  DEPENDS ON HOW I USE IT
LAST PIC TO PROTECT SWITCHES .. if you put a cap where the bulb is you get your engery u sent through and the colapse or kick..... 8) in that cap ...  first your hot then your cold ......
electricme
@All,
;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D
I have made all the necessary parts to assemble my newest Multiple Earth Electrode Battery/Cells, (this is getting to be a mouthful to say).
                           What should I or We ALL call it as?
Remember Greg posted a bit back it should be a Earth Cell Battery, so if everyone is happy with this ECB might be it's terminology.
I have made photos of every step of the way to document it.
                I have just come back inside to post I have a great success.
                              MY ECB WORKS as I expected it wood do.
      My best DMM says the ECB is putting out 5.33 volts in SERIES and climbing.
Thats right, I am getting a SERIES voltage out of 7 independant cells wired in series configuration.
                 ITS ALL IN THE INSULATION, INSULATION IS THE KEY
ALL THE CELLS ARE VERY CLOSE TO EACH OTHER IN THE SAME AREA OF GROUND
THEY ARE SMALL CELLS NOT LONG AT ALL, JUST SHORT TUBES WITH ZINC N 4 INCH NAILS POKEING IN THE MIDDLE OF EACH CELL
              THE OUTSIDE OF THE CELL IS COPPER PIPE  IT IS POSITAVE
           THE ZINC ROD IN THE MIDDLE BECOMES THE NEGATIVE OUTPUT
            WIND INSULATION AROUND THE OUTSIDE OF THE COPPER PIPE
                                       RAM IT IN THE GROUND
                          FILL THE CENTER OF THE PIPE WITH DIRT
              THEN WATER IT TO BED IN ALL CONTACT WITH THE EARTH.
                                               THATS IT
;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D
This means I Have SUCCEEDED in making a higher voltage out of a Series Connected Earth Cell Battery System.
I am excited, wooooooooah Whackooooo Yippeeeeeee
THE IMPOSSIBLE IS DONE          WAKEUP FOLKS         STOP SLEEPING IN THE BEDS
GETUP   TAKE A LOOK     YAHHHHHHHHOOOOOOOO   I'm giddy with successss
Photos dont lye        Proof             proof              proof
                           Arrrrrrh time for a cuppa Teeeeee
COMON WAKEUP ALL, USE PEOPLE GET OUTA BED, THIS IS HOORAY CELEBRATION STUFF.
GOSH look at all this above stuff, looks like IST was ere lol
JIM
lol
jeanna
Excellent Jim,
Now we will be able to know one way or the other if this is a galvanic battery and/or if the earth microbes or whatever will be able to supply the needed ions.
Until now it has all been guesswork and theory.
Thank you Jim for doing this!
Maybe you can run your Air conditioners on this... would that not be coool?
good stuff,
How about a scopeshot or 3 on the datalogging thread?
jeanna
