Joule Thief
0 Members and 124 Guests are viewing this topic.
FreeEnergyInfo
Ð"енераÑ,ор элекÑ,роэнергии по сÑ...еме Ð"рамма
(Ф-машина Фролова)
http://www.freelook.ru/index.php?option=com_content&task=view&id=40&Itemid=293
(Not by Mr. Frolov in this case, I just use this picture for reference, the source wants to stay anonymous, until his patent application is done and university verification tests will be done)
The claims are: 1200 Watts coil out with about 1076.4 Watts in into the driving motor at 3450  RPM. 8 amps @117volts at noload 9.2 amps @117 volts at full load
The output of about 1200 Watts is already a total overunity operation!
As they just increase the input power by about 140 Watts only between idle and load state and they get 1200 Watts output it seems indeed a case, where Lenz law is violated ! (the driving motor is inefficient in this case)
This generator also has NO motor effect ! If you supply current to the coil, the permanent magnet in the center will not rotate, cause the flux just stays inside the toroid core! There you can see, that the back drag does not influence the mechanical rotation of the magnet !
Regards, Stefan.
Hartmann Multimedia Service,
Dipl. In. Stefan Hartmann, Keplerstr. 11 B, 10589 Berlin,Germany
Tel: +49 30 345 00 497, FAX: +49 30 345 00 498
email: harti@harti.com  info@ccard.net
http://ccard.net fuer Ihren Verkauf im WEB!
jeanna
Was that a super cap, xee2?
I think what is interesting about those is that they charge much faster than they discharge.
Is that not supposed to be equal?
Nice green light. Too bad the picture doesn't show anything of the actual circuit that did it.
jeanna
jeanna
Quote from: FreeEnergyInfo on August 10, 2009, 04:50:49 PM
(Ф-машина Фролова)
I am sorry, but, I do not understand?
Can you explain, please?
jeanna
If you follow that link and read it you will find this from our own Stephan Hartman 1999
Quote(Not by Mr. Frolov in this case, I just use this picture for reference, the source wants to stay anonymous, until his patent application is done and university verification tests will be done)
Regards, Stefan.
stprue
Quote from: jeanna on August 10, 2009, 04:19:52 PM
Probably not, but what are you asking?
Near what?
Ah you answered my Q.
I need to snap a neo onto the end of the tube to start it, and I did that yesterday. So, except for that, I have not. Well not this year with the radiant experiments.
jeanna
I only ask because I have used neos on and around my cores and you can easily hear the frequency changing.  I have one powerful neo and when I physically put it on my new test core it appears to oversaturate my core and even with power still going into the JT nothing is comming out of the output side.  I found this very interesting.  Not only this but to me it seems like you can use neo's to change and or stabilize frequency.  Soon I'm going to try to make a tube vid and put this experiment on it.  My results as of now are me using a 1.3vAA for 10 sec. and then disconnecting.  After I disconnect the voltage keeps rising and then levels off...around 30-40vdc.  After it levels off the JT powers itself for at least 20min...not sure because I haven't timed it yet but its a good long while.  Also it will light an led for about the same time I think. This seems verrrry efficient to me what do you think?  I thinks the setup enables the 2 sometimes 3 maxcaPS to charge fully in 10-20sec.
FreeEnergyInfo
Quote from: jeanna on August 10, 2009, 04:56:21 PM
jeanna
copy text
go
http://translate.google.com/translate_t#
paste text
go
=englis text
veb
