Why does mass slow time?
Started by gravityblock, November 25, 2008, 05:31:30 AM
gravityblock
Traveling the Inverse Archimedes Spiral at C, to open the zero point dimension makes a lot of sense to me.
It appears that most if not all galaxies are connected to, or were connected at some point, to this zero point dimension due to the black hole's mass/energy causing it to open.  It also appears the galaxies are spiral shaped, similar to the Archimedes Spiral.
They have found so far, a black hole at the center of every galaxy they have studied.
This is how the galaxies are formed and created, through this zero point dimension, which makes up our universe and other universes operating on a different frequency of Time.
Traveling through a black hole's event horizon is not the best way to the zero point dimension, due to being torn apart by the black hole's gravity.
"Stolen waters are sweet, and bread eaten in secret is pleasant".
gravityblock
Quote from: triffid on June 24, 2009, 01:07:32 PM
Thats an interesting idea,trying to figure out a way to cancel mass.triffid
This is why light travels at C in all frames of references, either in a moving frame or a frame at rest, the results will be the same.  Since Time is used in the calculation of the speed, then Time ensures that the speed of light is calculated to have the same value in all frames, even though Time itself may not be the same between those different frames of references.
If you're moving at half C in a spacecraft, then Time may be ticking at half it's rate due to the increase in mass/energy of the spacecraft, which would cause the speed of light to be measured at C instead of half C, in both your moving frame of reference and in an outside observer's stationary frame of reference.
If Time was a constant or remained the same in all frames of references, then a moving frame would calculate C to have a lesser value than a stationary frame.  Study this concept.  Once you understand it, then it is no longer a mystery.
It is already mathematically proven that mass or energy slows Time and that Time affects mass also.  It is also proven to be true from scientific experiments thus far.
You won't agree or understand this, until you understand how the underlying principals of Time in the universe is working and having an affect on the physical world.  Time is variable and is not a constant value.  If Time was constant, then C would be variable traveling through the same medium between a moving frame and stationary frame.  Time is proportionally tied to the mass/energy in a system.
There will be no unification of the forces of nature until Time in the universe is taken into consideration and understand that Time itself is causing C to have the same value in all reference frames due to Time having a different value within those different reference frames.
triffid
An open ended loop of one turn(copper wire),ie a lakhovsky coil,is suppose to convert cosmic rays into electricity.We tend to think of cosmic rays as particles hitting the earth.Primary particles strike the top layers of the atmosphere causing showers of secondary particles.It is the secondary particles that we mostly see at the surface of the earth.Once in a while a primary will make it all the way to the surface.But cosmic rays are believed to occur everywhere in the universe.So we need to learn how to use the type of electricity generated by these coils.I really want want to say that gamma rays can be used in a lakhovsky coil too but I 'm not sure.Gamma rays tend to be rays and not particles.I do think gamma rays can cause secondary particles.Triffid
triffid
A rotating magnetic field would have an electric field  vector moving with it I am sure.But I know I will never build one myself(a marco rodin coil).Certainly not large enough to step inside of.I can still talk about it.I believe that if space can be stressed by a rotating electric field.That the future flow of time can be slowed down for any object in that area of the universe.If you believe that the closer a rocket gets to the speed of light that time slows down for everybody that is aboard .Just thinking out loud here again.triffid
triffid
So this is not a time machine but more of a" time slower down" machine.Time would slow down for anyone or anything inside of it.Triffid
