locating Steve Mark´s TPU demonstration house
Started by EMdevices, November 22, 2008, 09:00:43 PM
0 Members and 18 Guests are viewing this topic.
BEP
@jordas
When you use 'c' do you indeed mean speed of light in a vacuum or speed of light in the conductor?
Either way it seems the coils 'C' driving frequency would be very high???
I'll buy the 'relativistic' rotation.
>>Edit...
Interesting notion: I understand the relative vectors are all that really matter. 'c' in a wire is much less than 'c' in a vacuum. Drive the coils 'C' with a simple multivibrator or 555 setup with only two outputs - alternating. Two outputs because there are two sets of 'C' coils. All we need then is to make the frequency 'look' like it is travelling faster than current 'could' travel in that 'A' wire and we break the sound?? barrier?
Even when coils are right angles to each other there is induction, of a sort. The only thing induced is the rise and fall of the driving signal. In this case (A surrounded by C) only one is induced? The rise or the fall?
I tried this all before in different ways. Guess I never hit the right frequencies  :(
innovation_station
if i remember correctly ...   the freqs were close in the audio ver ...   like 2 real close  and turn 1  to change speed and dirrection this was useing 3 speekers 3 amps 3 laptops ..   this rotation sounds verry wild ...  almost like a race car  going round a track   with a kinda ring to it ...
so i have herd ....
ist
i dont think the freqs matter so much ...  they need to be set to your coils to ringggg em  ;)  3rd to rotate.... 8)
EMdevices
Harmonic resonance on parallel high voltage transmission lines
Harries, J.R.; Randall, J.L.
Power Delivery, IEEE Transactions on
Volume 12, Issue 1, Jan 1997 Page(s):477 - 482
Digital Object Identifier   10.1109/61.568274
Summary:Harmonic resonance has been observed, measured and modeled on parallel 500-kV lines that are about one wavelength at 2100 Hz, the 35th harmonic. A seemingly small harmonic injection at one location on the system causes significant problems some distance away such as telephone interference
I've given you a new direction forward, but I see people are in love with their fantasies.  Happy dreams, may the muons be with you!!!
EM
Gobaga
Quote from: jordas on November 24, 2008, 07:39:07 PM
Even if the rotating speed is less than c there are other effects involved due to the existence of an external magnetic field.the geomagnetic one.
What sort of "effects"?
Let's suppose, hypothetically, that I don't believe in fields and rather than rotate a magnetic field, I want to rotate the underlying potential that supports the existence of the magnetic field.  After all, Stephan Marinov claimed emphatically, that there are no "fields" - only "potentials" and since a magnetic field is dynamic, something is causing it.
So, what is really rotating?  A change in the potential?
chrisC
Quote from: EMdevices on November 24, 2008, 10:58:56 PM
EM
@EM
so are you now totally convinced that SM somehow found a way to tap 1000W of power from high tension power lines delivered to his TPU's? End of story?
I think the detective work you did on the mansion and related power lines is awesome! You should be a private investigator!
cheers
chrisC
