Cavitation. The key to overunity?
Started by Pirate88179, November 29, 2008, 10:50:09 AM
CrazyFox
@ THEBUZZ
Salt water (1% to 3% by weight) in the Clem Engine converts water mass to energy. If the polar ethanol is used, the ethanol reforms and x amount of mass converts to heat and light energy. However, no radiation with ethanol and a lower operating temperature is achieved. Both external heat and ethanol need to be added from time to time. Conservation of energy in action. The thermal characteristics of ethanol less any surfactant (shell) are far smaller than salt water. I have not researched surfactant shell configurations for ethanol to improve dielectric bubble capacitance that may or may not enhance ethanol for mass conversion. It too may provide nuclear fuel with proper configuration and run at a lower temperature. My analysis of the Clem Engine was confined to the elements presented and deduced based upon Clem's life style. Sulphco, Inc has a process to catcrack sour crude oil using water cavitation in oil to separate sulfur from the sour crude. The sulfur forms beads and is filtered out. Clem had contact with refinery people at the Bar/Cafe he went to after work. This seed idea has, after years of maturing, become something that could turn the energy world upside down.
Grumpy
Quote from: TheBuzz on December 17, 2008, 04:10:41 PM
O.K., I bite. I honestly don't know much about the device. I just Googled that and scanned what Naudin had wrote, pasted the link in.
From what I do remember about Meyl, he produced two longitudinal waves with a common ground plane in the form of a copper wire.
Since particles are held into a lump using two scalar waves, I would assume that they are de-spinning that scalar wave of the mass. Where is the mass being converted? I would assume on or in the capacitors above the coils. I also assume the parametric wave associated with the pancake coil has an acceleration property to it similar to the mechanical action of a bull whip.
What best defines my knowledge of this particular device is what I don't know since this is one I have never looked at it closely.
One thing is for sure, whether it is a receiver or a mass to atomic energy converter, the OU comes from somewhere and some magical buzz word like zero point or aether does not explain anything.
Let's hear your thoughts since you brought it up. Don't worry Grumpula, the trolls have already been fed.
What is a longitudinal wave - to you?
        -Frank Edwards
AbbaRue
The way I understand Tesla's Magnifying Transmitter is:
You build 2 identical units and use one as the transmitter and the other as the receiver.
The antenna of each one is build to function as the plate of a capacitor.
That is why he used spheres so they could interact with each other better at a distance.
Two spheres will always be parallel to each other in space.
If you used flat plates that were exactly parallel to each other that would work even better.
Somehow energy is collected from the space between the two plates as you transmit and receive.
The measurements show that there is more energy coming out of the receiver then what was transmitted.
This is how I understand the essence of the device anyway,
don't think anyone else has ever put it this way before me.
I wonder if the larger the plates the more energy it would collect?
If someone has 2 identical ignition coils or flyback transformers maybe they could test this.
Use Naudins circuit setup.
At the following site you can see what I am talking about.
http://jnaudin.free.fr/html/lmdtem.htm
The "longitudinal waves" setup uses coils separated by capacitors.
Now if we tuned the two circuits to a Rife frequency that kills cancer cells,
then a person could sit between the plates and cure the cancer while generating electricity. ;D ;D ;D
Paul-R
Quote from: TheBuzz on December 18, 2008, 08:14:40 AM
A Tesla coil produces a longitudinal wave, a solonoid coil produces a transverse wave.
The difference between pulling on a rope and shaking a rope.
What a fantastic metaphor.
sparks
    The Earth acting as an inductor and the atmosphere as the dielectric in a resonant circuit is a cool idea but how would one first create a waveguide and secondly damp such a wave to say charge a battery bank.  My little transistor radio runs off a piece of copper wire attached to ground but hell to pickup any kind of meaningful power we gotta go with one big old piece of wire.  The only way I can see is get some kinda magnetic hurricane going that creates magnetic currents inside the Earth so we dont need such a big piece of wire.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
