Cavitation. The key to overunity?
Started by Pirate88179, November 29, 2008, 10:50:09 AM
CrazyFox
@Sparks
The Cern experiment is about to find out how magnetic reconnect with the magnetosphere causes uncontrolled plasmas outside the ring accelerator. At the resonant frequency of the earth (16-60 KHz) a conduit is provided by the atmosphere. and magnetic vortexes form along the path of the pulsed ring accelerator (eddy currents) that will shut down the accelerator from plasmas created.
You might try to pick off power at the earth's resonant frequency with a large magnetic loop. Caution: Lightning can come from the ground or above and fuse your receiver. Cern may want to magnetically shield (contain the pulsed field) to prevent stray uncontrolled plasmas from forming. A harmonic resonance with the pulse frequency and the earth's resonant frequency my have dire consequences in the form of a worm hole. A wave guide would only be effective in the microwave end of the spectrum. One other problem is the resonant frequency not being constant so you would have to track the drift with automatic fine tuning. Marconi and Tesla failed to figure the magnetic reconnect in their world transmission scheme. Plasmas would have fused their equipment at some point.
Grumpy
Quote from: TheBuzz on December 18, 2008, 08:14:40 AM
A Tesla coil produces a longitudinal wave, a solonoid coil produces a transverse wave.
The difference between pulling on a rope and shaking a rope.
Since a pancake coil is a capacitor on the side of opposite polarity and magnetic field producing a parametric wave, I assume that is how we get there using that as the primary. To me anyway.
With a longitudinal wave only the medium expands and contracts - no electrons move across vast distances - hence the superliminal velocity that Tesla measured.
If the medium is capable of changes in density then it can be cavitated.  This is exactly what Tesla did with a massless medium that is not constrained by laws that require mass.
One other thing about longitudinal waves - the magnetic field vanishes.
In the Tesla Magnifier, both the earth and the atmosphere became conductors for this massless longitudinal wave.  All the talk of bouncing stuff off the ionosphere and conducting waves through the earth is BS.  If you have a working magnifier, you can pull and large amount of conventional electricity right out of the empty space adjacent to the extra coil of the magnifier - if you cannot then it is not tuned properly - period.  Many tune them for long sparks - not a one tunes for the real deal.
        -Frank Edwards
Grumpy
Quote from: sparks on December 18, 2008, 11:24:11 AM
    The Earth acting as an inductor and the atmosphere as the dielectric in a resonant circuit is a cool idea but how would one first create a waveguide and secondly damp such a wave to say charge a battery bank.
The earth is a dielectric - big secret, by the way.
The "waveguide" is created because an electric line of force can not end in space and must end on a conductor - there is your waveguide.  The energy is not dumped through the wire but around it.
        -Frank Edwards
sparks
   Tesla wanted to produce lightning strikes to create a pole from which he could radiate energy.  In accomplishing this lightning strike efficiently he drew on a scource of energy which is the dielectric polarization of I would say everything.  By causing a resonant current to travel between his elevated terminal and his ground terminal I believe he was able to have the dielectric field flux surrounding his top load capacitor feed into his circuits.  When his elevated terminal becomes relative to the dielectric field potential surrounding it there is a flow of energy into the circuit.  The input to this resonant secondary is not conveyed by tight inductive coupling to the primary in any way.  Therefore the secondary resonance is allowed to gain momentum independent of the exciting scource.  The frequency of this secondary resonant circuit was controlled so that transverse waves were minimized requiring the frequency to be quite low.  Between 6to20khz.  The cavitation seems to occur in his top load capacitor plate which at Wardenclyffe takes on the form of a hemisphere.  I really don't think he wanted to pull a giant spark out of the neighborhood.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
sparks
    I believe the magnifying transmitter was a means to an end.  The secondary of the transformer resonates at whatever wave length he wants to radiate as a longitudinal wave in the Earth.  The system runs with gain with input at the split capacitor plates.  One the top load and the other that big steel thing underground.
Think Legacy
Spread the Love
