If you give me fifteen minutes I can show you how to change the world.
Started by shecum, December 07, 2008, 03:35:03 AM
Mark69
Anyone building??  I would like this to make a hydrogen powered home furnace and get rid of nat. gas.
Mark
CrazyEwok
Ok for starters IF this is true you don't need and micro processor and if you built a cell i would say you posses the knowledge and skills needed to create a control method...
3 things i can see that you would need...
1. (you should already have i would hope) a reserve tank and small pump to maintain a certain level in your reaction chamber. This should minimize the change in the frequency required.
2. A way to constanly remove your generated "free" electrons that are staurating your cell, preventing your continued production. (i have an idea on this... 2 pumps so that the water in the cell is constantly cycling and then you can have a device in the reserve tank to extract the charge. This may or may not work but maybe some sort of net connected to some capacitors... I am sure there are people out there that can come up with better ideas but till then you could maybe just ground the net and simply syphon this charge out of the water for now)
3. A small "clip-on" sliding switch that can adjust the resistance on your alternators poles (where you "tune" your alternator to give of the right frequentecy) turn your dimmer measure the resistance and then by a resistor as your sliding switch reaches certain points on your throttle control to "jump" the cell into different levels of production. (if not on the throttle control perhaps a pressure switch in the lines so as the pressure is removed it kicks the production up) no micro processor needed. Leave the micro processor level to the people that want to prefect the process to a fine art. Remember this tech is still in the "Model T" days just get it to work and it will evolve into a precise art later down the track :).
I hope if this helps you and you get a working model. If you accept your millions you can atleast throw me a bone (or detailed construction) of your cell and implementation purely for private use :). If not i am sure that you can make your millions with only a few investors.
Good luck!!!
infringer
all I can say is blacklight power may have something worth checking...
-infringer-
REGISTER AND BECOME A MEMBER RIGHT NOW!!!!!
........::::::::: http://www.energyinfringer.com  :::::::::........
"""""""everything is energy and energy is everything""""""
-infringer-
forest
Quote from: CrazyEwok on December 08, 2008, 09:28:54 PM
as long as water is touching both terminals totally there is no need to maintain certain level , I will explain  it below
the best way for now is to remove free electrons are by connecting a metallic mesh placed between terminals in water to the natural ground by a current consuming device. Exactly what Meyer did, and Dingel showed in video also.that is why Meyer COATED his electrodes with delrin ! to prevent displacement current to flow back to the oscillator and you see it could be used ONLY with EEC
this is also explanation why maintaining certain level is not needed and why adjusting frequency is not needed - WFC is a capacitor NOT IN COMMON SENSE - it does not store charge from oscillator, but from displacement current - electrons dislodged from water
Good luck!!!
CrazyEwok
wouldn't connecting the electrodes short circut the system?
If your electrolizing the water you will need to replace the water you use. In order for this to work you need a working area variable. in other words 2 levels that your system will work between. 1 - a full level where the system no longer needs any more water replaced and 2 -  an empty level where the cell is at its lowest point of safe efficient operation. So unless you can claculate the exact amount of water that need to be replaced as the reaction is increased in order to keep the cell at the exact level of the electrodes, I think a working level will work great...
Since water is a fluid and your looking at solving the problem of it being over charged can you put a "liner" around the outside of the reaction that is grounded (rewired into something that can utilize the charge if you so wanted) so that the created charges will travel through the fluid to the liner thus drawing it away from the electrodes. Or do you think i am being to optermistic?
